Jon sweet Posted January 12 Share Posted January 12 How do I change mt entry / bay door combination on the door handle? Jon Sweet Link to comment Share on other sites More sharing options...
jacwjames Posted January 12 Share Posted January 12 What make/model of keyless entry do you have? Check your manual, I have a section in mine explaining how to change the code. In my case it says to find the reset button hidden somewhere in the dash. When I first bought my coach I looked everywhere, couldn't find it. The wiring diagram shows that the reset wire just goes to ground so was able to access the back of my key pad via the passenger side console and wired in my own momentary switch to reset the codes. Several years later while working on something else I found a black wire loom hidden in a bunch of other wires with the end taped up, took the tape off and there was a red button, which was the reset button. Link to comment Share on other sites More sharing options...
Dr4Film Posted January 12 Share Posted January 12 As Jim stated, make and model is needed plus the instructions should be in your owner's manual if you have one. Otherwise, a search on the Internet will also supply the correct procedure depending on the make and model. Link to comment Share on other sites More sharing options...
LakeBob Posted January 12 Share Posted January 12 The instructions are fairly straightforward, I was able to change mine without using the reset button. On my coach, I did find the module through the dash opening above the steering wheel. It was on a ledge just below the windshield. Link to comment Share on other sites More sharing options...
Jon sweet Posted January 13 Author Share Posted January 13 Thanks for the input,I'll search for the reset button. Jon Link to comment Share on other sites More sharing options...
jacwjames Posted January 13 Share Posted January 13 1 hour ago, Jon sweet said: Thanks for the input,I'll search for the reset button. Jon I looked in a manual for a 2009 Camelot, not sure what make you have, it shows one that is mounted in the grab bar. It does not give instructions as how to reset the codes so it may be different then mine. It only says to refer to the OEM manual, so if you got all the individual manuals for your coach it may be in there. Maybe someone with a Camelot or a similar keyless entry system will respond. Link to comment Share on other sites More sharing options...
Happycarz Posted January 14 Share Posted January 14 Jon, I sent you a PM. Link to comment Share on other sites More sharing options...
Matt Lavender Posted February 5 Share Posted February 5 On 1/13/2023 at 7:31 PM, Happycarz said: Jon, I sent you a PM. Hello, do you still have the instructions? I have a 2008 40pdq Scepter, which is basically identical to the Camelot. Thank you, Link to comment Share on other sites More sharing options...
Happycarz Posted February 5 Share Posted February 5 I do. Send me a PM with your email or phone number and I’ll email or text them to you. Harry Link to comment Share on other sites More sharing options...
Chris Leedle Posted February 6 Share Posted February 6 I have the instructions for resetting the keypad on my 2007 Camelot. I am in Japan right now but will be home in a couple of days. If you do not get an answer PM me and I will send you a copy of the directions. Link to comment Share on other sites More sharing options...
Happycarz Posted February 7 Share Posted February 7 Anyone on the forum here that wants the instructions will have to PM me. As I have said in the past, I as well as others, could gain entry to your coach if only the keypad lock is used. So, use your deadbolt! There is an AUTHORITY code and an ACCESS Code. Most folks don’t know how or just haven’t changed the default AUTHORITY code from the factory. You need to use the AUTHORITY code to change the individual user codes, AKA ACCESS codes. I’m willing to share the procedure for creating your own ACCESS codes, but not on a forum. I created a cheat sheet to make it easier to change codes, along with how the owners explains it. I’m willing to share if you will PM me an email address or phone number if you prefer text. This is for the TriMark keyless entry system. Link to comment Share on other sites More sharing options...
Frank McElroy Posted February 10 Share Posted February 10 On 1/12/2023 at 7:18 AM, Jon sweet said: How do I change mt entry / bay door combination on the door handle? Jon Sweet Members of our forum have access to the file downloads. The information you need should be in the attached link. If you click on the title "Trimark Keyless Entry System" you'll get a link to multiple documents. This is a link for the Essex system. Again click on the title to see all the file downloads. Link to comment Share on other sites More sharing options...
