bigbhb Posted January 18 Share Posted January 18 Need to adjust ohd awning.The fabric goes out to far, causing arm to extend to far and lock,then cannot retract awning Can't find manual to get end cap off,don't want to break it. serial # is on rail behind cap. not sure if this model has adjustment on it,others when you extend them you can see the 2 adjustment arrows. 2006 monaco holiday rambler. any help would help thank you Link to comment Share on other sites More sharing options...
Tom Cherry Posted January 18 Share Posted January 18 2 hours ago, bigbhb said: Need to adjust ohd awning.The fabric goes out to far, causing arm to extend to far and lock,then cannot retract awning Can't find manual to get end cap off,don't want to break it. serial # is on rail behind cap. not sure if this model has adjustment on it,others when you extend them you can see the 2 adjustment arrows. 2006 monaco holiday rambler. any help would help thank you @throgmartin Chris Throgmartin is a member and our resident expert of awnings and toppers. He started out making Toppers and was a great source for many of us. He has expanded his business and has an RV repair shop in Brooksville, FL. His techs are specialists in awnings and toppers. However, Google is your friend and source. Here is the manual with all the poop... https://www.carefreeofcolorado.com/wp-content/uploads/2022/06/052978-021-Freedom-Installation-Manual.pdf Good Luck. Read it and then if you need help, contact Chris.... Link to comment Share on other sites More sharing options...
Ron Shantos Posted January 18 Share Posted January 18 Brian, below is a picture of the endcap and where the tabs are located to remove it. Hope this helps. Ron Link to comment Share on other sites More sharing options...
bigbhb Posted February 1 Author Share Posted February 1 Thank you to everyone. Unfortunately the awning that I have does not have adjustment on it. Thank you Brian Link to comment Share on other sites More sharing options...
