grizzly Posted January 23 Share Posted January 23 Have a question if any of you have had similar problems.I have a 07 Monaco signature. On the bay doors there are sensor switched that let you know if oner of the doors are open when you start the coach. I checked them all and adjusted and replaced ones that were broken. On my dash on the odometer bottom it still reads bay door open . Any ideas? Link to comment Share on other sites More sharing options...
Jim Pratten Posted January 23 Share Posted January 23 We had similar issue, slide wouldn’t come in. Go to each door switch, pull the spade connectors off the switch and connect them to a 5 amp auto fuse. If it’s a switch, you’ll find it this way. Remember, don’t operate the slide with the door open. Forget the details but was able to open the switch, clean it and returned it to service. Link to comment Share on other sites More sharing options...
grizzly Posted January 23 Author Share Posted January 23 3 minutes ago, Jim Pratten said: We had similar issue, slide wouldn’t come in. Go to each door switch, pull the spade connectors off the switch and connect them to a 5 amp auto fuse. If it’s a switch, you’ll find it this way. Remember, don’t operate the slide with the door open. Forget the details but was able to open the switch, clean it and returned it to service. The slides work fine. Just annoying that message is still there. Before I replaced some of them, if I pulled off the connectors on a few then it would go off. Just weird Link to comment Share on other sites More sharing options...
Ray Davis Posted January 23 Share Posted January 23 10 minutes ago, grizzly said: Before I replaced some of them, if I pulled off the connectors on a few then it would go off. Just weird I suspect you have another bad switch or one out of adjustment. 1 Link to comment Share on other sites More sharing options...
grizzly Posted January 23 Author Share Posted January 23 2 hours ago, Ray Davis said: I suspect you have another bad switch or one out of adjustment. I ADJUSTED THEM ALL ALREADY. THEY ARE JUST PUSH TYPE. AS SOON AS DOOR HITS THEM IT PUSHED THEM AWAY THUS BREAKING THE CIRCUT. WILL TRY REMOVING SOME TOMORROW. GREMLINS. LOL Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted January 23 Share Posted January 23 Please do not type in all caps, that denotes shouting. You need to adjust the brackets that hold the switches. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
grizzly Posted January 23 Author Share Posted January 23 2 hours ago, Chuck B 2004 Windsor said: Please do not type in all caps, that denotes shouting. You need to adjust the brackets that hold the switches. Chuck B 2004 Windsor Sorry my mistake. Wasn't shouting Link to comment Share on other sites More sharing options...
