CrewChiefPro Posted January 24 Share Posted January 24 I can't seem to find any fuse labeled for the patio lighting, anyone know the location? Link to comment Share on other sites More sharing options...
Tom Cherry Posted January 24 Share Posted January 24 You may have 2 fuses or ONE. OR you may have an issue with one of the 3 or 4 CCM’s upfront. You have the CCM system where all the dash switches and such are controlled by a Multiplex Kongsburg (?) brain or control box. That is then linked to a bunch of individual Control Boxes (CCM) all over the MH. I’m sure you understand what a BCM is on today’s cars, you have the equivalent. You actually have TWO Mulitiplex systems, One inside a closet with a CPU and a bunch of output or control modules. That is what controls all the lighted house switches for lights and slides and fans and god knows what else, The Patio lights are PROBABLY controlled by the Chassis system. Look in your manual and read up on the CCM. You can typically find the fuse layout there. If not, find the print for the light or the switch that controls it. Odds are there is a CCM circuit for it and that will tell you which CCM, if I am correct, controls it and where the upstream, as well as possibly the individual fuse for the CCM is. This ain’t your ordinary on/off switch like what was in your grand or great granddaddy’s Oldsmobile…..LOL. Seriously, some folks may help so they can chime in, but the real resource is the prints and also then understanding the system. After reading and looking at your website, I apologize if I talked down to you…but you might not be familiar with the two systems on your nice rig. Good Luck….keep us posted…. Link to comment Share on other sites More sharing options...
CrewChiefPro Posted January 24 Author Share Posted January 24 I have been looking for any fuse labeled Patio or Accent lighting, have not found a bad fuse anywhere. The switch for the outdoor patio lighting is right next to the door, and I don't believe it goes to a CCM. Since I see a frayed wire under the slide out, and have yet to find a blown fuse or any other lights that do not operate, a CCM may be the issue. I will continue to investigate and let you know. Link to comment Share on other sites More sharing options...
Tom Cherry Posted January 24 Share Posted January 24 I am NOT the guru on the Dynasty and above....as the prints are totally foreign to my experience. BUT, here are the prints for them. You will need to download the entire file if you don't have them. The INDEX (shown above) is the easiest to follow....look at these 38050052 Board F1 - you are looking for PORCH LIGHT....if I remember.... 38080034 Again....this is two pages Look at the switches. Then scroll down. There is an M157 Connector. Somewhere there is a pin out of this....but I am not that good 308040159 This is like another LOOK at the boards with MORE detail. You need to read the manual and learn HOW the boards work. NOW...I can't quite recall how the CCM integrates. @Frank McElroy is the curator of the prints and also understands the CCM and such. He may chime in and help you. Good Luck....please let us KNOW what you find and how you resolved this. This is how we all learn... Thanks, Link to comment Share on other sites More sharing options...
Frank McElroy Posted January 24 Share Posted January 24 The porch light is controlled by the CCM in the FRB. One of the wires on connector J4 out of the CCM will be labelled porch light. If the other two switches on the porch light switch module work, then either the MOSFET output from the CCM feeding the porch light wire is current limiting due to a shorted wire/bulb or the MOSFET internal to the CCM is bad. There is no separate fuse. The MOSFET circuit internal to the CCM is providing current limiting and is acting like a fuse. This is the link you need for wiring diagrams on a multiplex coach like yours. If you click on the title "2008-9 Dynasty..." you'll get an option to download all schematics in one file. If you click on "Download this file" you can select each page separately to download. Link to comment Share on other sites More sharing options...
CrewChiefPro Posted January 25 Author Share Posted January 25 44 minutes ago, Frank McElroy said: The porch light is controlled by the CCM in the FRB. One of the wires on connector J4 out of the CCM will be labelled porch light. If the other two switches on the porch light switch modules work, then either the MOSFET output from the CCM feeding the porch light wire is current limiting due to a shorted wire/bulb or the MOSFET internal to the CCM is bad. There is no separate fuse. The MOSFET circuit internal to the CCM is providing current limiting and is acting like a fuse. This is the link you need for wiring diagrams on a multiplex coach like yours. If you click on the title "2008-9 Dynasty..." you'll get an option to download all schematics in one file. If you click on "Download this file" you can select each page separately to download. Thank you, I appreciate the information. However, I can't find anything in the file that lists SLIDE LIGHTS on a Signature. I have a switch that is labeled "Porch Light" and it works fine, my problem is the lights UNDER the slide outs. Link to comment Share on other sites More sharing options...
vito.a Posted January 25 Share Posted January 25 IF the under slide lights are controlled by the CCM, then there may indeed not be a fuse. Quote: The CCM uses electronics for current limitation of circuits rated up to 12 Amps. Any circuit rated 12 Amps or less, in many instances, will be fused electronically instead of by a mechanical fuse or circuit breaker. When a command is given to turn on a specific circuit (fog lights for example), the CCM will continually monitor the fog light circuit to prevent overload, such as a short circuit to ground. If an over-current condition should occur (short), the CCM will electronically turn off power to the circuit. The CCM will log the fault into memory and that information can be retrieved by a service technician. When the problem is corrected, the circuit is automatically reset through electronics. Link to comment Share on other sites More sharing options...
CrewChiefPro Posted January 25 Author Share Posted January 25 (edited) It appears to be factory. I have seen these on other Signatures but anything is possible. Here is the picture of the switch panel near the passenger side armrest. The switch is the one on the bottom. I will remove switch panel tomorrow and trace the wiring and see where it ends up. If I can't find it, I will run a fused wire from another area. OK, I have confirmed that this is an optional Monaco Signature feature, and was put on from the factory. I found it in the owner's manual on page 133. Edited January 25 by CrewChiefPro Link to comment Share on other sites More sharing options...
Frank McElroy Posted January 25 Share Posted January 25 Well, I learned something new. The owners manual does show an optional exterior accent light for under the slides. First I've ever seen it. I'll look to see if Monaco included a schematic for it. Link to comment Share on other sites More sharing options...
Frank McElroy Posted January 25 Share Posted January 25 OK, I found the two schematics you need they are 38090017 (p113) and 38081042 (p162) Fuse F11 2A. I'm checking but I think it might be in the cabinet with the house multiplex system on a small fuse block with about a dozen fuses. Link to comment Share on other sites More sharing options...
CrewChiefPro Posted January 25 Author Share Posted January 25 Those fuses are all good. Link to comment Share on other sites More sharing options...
Frank McElroy Posted January 25 Share Posted January 25 The two schematics should help in sorting out the problem starting with whether power is getting to the switch and the grounds are good. Link to comment Share on other sites More sharing options...
