wbperry1939 Posted May 30, 2020 Posted May 30, 2020 After a two year fight with the King Control throttle on my 1998 Monaco Windsor, I am ready to give up. After the last "repair" we drove it 7 hours. No problem. I sold it yesterday and the new owner had three failures on the way home. I went and retrieved it and gave him his money back. Returning with it - no problem. I refuse to sell my problems. Questions for those who have done the conversion to air throttle. Is the air modulator for the 3060 Allison the only thing needed for the transmission or are there other considerations? Which throttle pedal arrangement: through the floor, floor mount, or firewall mount? Does the King Control cruise control still work without the King throttle pedal? Happy with conversion? Any information is much appreciated. My wife decided that at age 80 I no longer need a motor home. I don't know if she is right, but then she is always right. So I do need to get it fixed up right and sell it. Bill
JamesW Posted May 30, 2020 Posted May 30, 2020 (edited) I have Williams Throttle Air Control on the foot pedal side. Please include any observations about KC-2500 “King Cruise Control” as well for any other responders. I’m trying to sort mine now and return it to function. Thx Jim 1995 Dynasty, C8.3L mechanical Edited May 30, 2020 by JamesW
wbperry1939 Posted June 7, 2020 Author Posted June 7, 2020 JamesW, if you presently have the Air Throttle why are you considering returning to the King Control throttle? Many hours of mechanic time have been invested in getting my King Control throttle to work reliably without success. We are considering switching to the William Air throttle. With the air throttle, does your King Cruise Control still work? Bill Perry, 1998 Monaco Windsor, 8.3L mechanical.
CRY1942 Posted September 1, 2020 Posted September 1, 2020 I have the King 2600 Throttle & Cruise Control, it was rebuilt last year and working well. But the the advent of Control King closing up, have great interest in converting to the Air Throttle. Does anyone have specific details on your conversion ? Did you add a Throttle Position Sensor ? Where does the Allison get its vehicle speed input, which is now coming from he King ? Thanks.
wbperry1939 Posted September 2, 2020 Author Posted September 2, 2020 At age 81 I planned to sell my 1998 Monaco Windsor, but wouldn't do it with the King Control knowing it couldn't be serviced. And it had intermittent problems. So we put on a Williams air throttle. Bought a floor mount (top of floor) pedal assembly and a matching actuator. We took the throttle return springs out of the King pedal assembly and attached it to the Williams to get throttle position info just as original. When the Williams pedal goes down it pushes the King unit proportionally. The King part that was attached depended upon the spring in the original throttle position sensor to return it to idle when the pedal was released. This part requires a skilled fabricator. In the rear, we fabricated a bracket to mount the actuator just to the front of the King actuator which was left in place as original. So cruise control still works (for now). The Williams actuator was positioned so that the cable ran under the King and very close to it. We replaced the stud-type link for the King on the fuel injector pump with a 3/8 inch Heim joint. Another Heim joint was put on the other side of the fuel injector pump level for the air throttle. We used cable and connectors purchased from Aircraft Spruce to connect the new throttle cable. The air throttle is a huge improvement over the King. Throttle response is immediate unlike the slow reacting King. Very nice when pulling out from a stop sign onto a busy highway. We should have done it years ago. Sorry I didn't take photos, but the Monaco is 1700 miles away now with it's new owner. Bill Perry
CRY1942 Posted September 3, 2020 Posted September 3, 2020 Thank you, Bill, all input on this pending issue is appreciated. I think there will be a number of owners faced with replacing the King Control sooner or later. Regards,
Marty K Posted September 8, 2021 Posted September 8, 2021 I am in need of some detail as to making the King Cruise conversion to air throttle plus the need for some older type throttle position sensor. If at all possible pictures would be great. I can not find anyone that has any knowledge locally about this conversion. Any help would be greatly appreciated. Marty
CRY1942 Posted September 10, 2021 Posted September 10, 2021 Southwest International Truck Center in Dallas has completed one Country Coach conversion to an Air Throttle and Rostra Cruise Control, reportedly at a large expense. Conversion for air throttle requires a new Air Foot Pedal, Air Lines front to rear, Air Throttle Control Cylinder, Throttle Position Sensor (TPS) and a new pickup for vehicle speed. King Control box provided Throttle Position and Vehicle Speed to the Allison transmission. I am working with an owner who is about 99% complete with his conversion on a Cummins C8.3 and hope to soon have details available. See Coach Conversion Central (.com) for basic information on air conversion.
