grizzly Posted February 1 Share Posted February 1 Have a new circulating pump I installed and has worked fine but now every once in awhile I have to go out and tap it for it to start running. I have an older one that does the same thing.Any ideas why? Im thinking possible check valve issue Link to comment Share on other sites More sharing options...
vito.a Posted February 1 Share Posted February 1 Usually when a pump doesn't start it's either the armature is bad, or the pump impeller is sticking. You could try taking it apart to see if it spins freely. I saw on IRV2 that lots of the newer Newmar and Entegra folks are having pump issues. One of them posted an alternative pump that is much cheaper. Link to comment Share on other sites More sharing options...
grizzly Posted February 1 Author Share Posted February 1 1 minute ago, vito.a said: Usually when a pump doesn't start it's either the armature is bad, or the pump impeller is sticking. You could try taking it apart to see if it spins freely. I saw on IRV2 that lots of the newer Newmar and Entegra folks are having pump issues. One of them posted an alternative pump that is much cheaper. thanks. the one pump is only about 3 months old. the other I have no idea Link to comment Share on other sites More sharing options...
vito.a Posted February 1 Share Posted February 1 See if they will warranty the pump. Link to comment Share on other sites More sharing options...
96 EVO Posted February 1 Share Posted February 1 Are you tapping the pump itself, or the zone valve for that zone? If the pump, next time it happens, try tapping the brass zone valve instead. Link to comment Share on other sites More sharing options...
vito.a Posted February 2 Share Posted February 2 Here's the link to the alternative Aqua Hot pumps: https://www.irv2.com/forums/f278/this-is-my-final-installment-on-the-ah-pump-dilemma-528495.html Link to comment Share on other sites More sharing options...
grizzly Posted February 2 Author Share Posted February 2 3 hours ago, 96 EVO said: Are you tapping the pump itself, or the zone valve for that zone? If the pump, next time it happens, try tapping the brass zone valve instead. thanks Link to comment Share on other sites More sharing options...
