grizzly Posted February 2 Share Posted February 2 I read that a lot of you have replaced your air bags yourself. My question is how difficult is it and any special tools you need. FYI I grew up on a 2000ac farm and am very handy with tools and fixing most stuff. Just looking for advice. I know cost of bags is reasonable but finding someone to do work could be an issue where we are. Not a pressing issue but just looking for input. Thanks Link to comment Share on other sites More sharing options...
seawayvm Posted February 2 Share Posted February 2 Replaced air bag on the front of my Imperial, very easy job, no special tools needed. Link to comment Share on other sites More sharing options...
Hypoxia Posted February 2 Share Posted February 2 (edited) 2007 Monaco Signature Noble III Air Springs All Air Springs on the coach are the same regardless of position, Steer, Drive, Tag Steer Axle: Four Air Springs Conti Tech 99-12P 730 (AS8897) (64664) Removal: 1 ¼” wrench & Large Crescent - remove air nut first 1 1/8” Socket & Flex ratchet – remove fitting (fitting will not fit through the 1 1/8” hole) ¾” Socket – remove two upper and two lower nuts last & remove bag Drill hole to at least 1 ¼” and fitting won’t have to be removed next time Firestone W01-358-8897 with 3/4" inlet, W01-358-9376 with 1/4' inlet, Triangle AS-8730, TRP AS88970 9 9-12 P 730 Hockydiesel had some great tips such as breaking the air fitting off instead of unscrewing it, etc. It's not a technical job but takes a variety of wrenches, ratchets and impact wrenches along with some strength and patience. Edited February 2 by Hypoxia Link to comment Share on other sites More sharing options...
grizzly Posted February 3 Author Share Posted February 3 35 minutes ago, Hypoxia said: 2007 Monaco Signature Noble III Air Springs All Air Springs on the coach are the same regardless of position, Steer, Drive, Tag Steer Axle: Four Air Springs Conti Tech 99-12P 730 (AS8897) (64664) Removal: 1 ¼” wrench & Large Crescent - remove air nut first 1 1/8” Socket & Flex ratchet – remove fitting (fitting will not fit through the 1 1/8” hole) ¾” Socket – remove two upper and two lower nuts last & remove bag Drill hole to at least 1 ¼” and fitting won’t have to be removed next time Firestone W01-358-8897 with 3/4" inlet, W01-358-9376 with 1/4' inlet, Triangle AS-8730, TRP AS88970 9 9-12 P 730 Hockydiesel had some great tips such as breaking the air fitting off instead of unscrewing it, etc. It's not a technical job but takes a variety of wrenches, ratchets and impact wrenches along with some strength and patience. Thanks. Just now, grizzly said: Thanks. Do you need to block anything up when you are removing the air bag so it doesn't come down? Link to comment Share on other sites More sharing options...
Ivan K Posted February 3 Share Posted February 3 You will of course need to block between h-frame and frame rails. I used 4x4 lumber but what ever is safe. I also found a small air impact very helpful where I did not have enough space to even make a ratchet wrench to click up top. Especially the bag by stair well would have been near impossible for me. Link to comment Share on other sites More sharing options...
grizzly Posted February 3 Author Share Posted February 3 Just now, Ivan K said: You will of course need to block between h-frame and frame rails. I used 4x4 lumber but what ever is safe. I also found a small air impact very helpful where I did not have enough space to even make a ratchet wrench to click up top. Especially the bag by stair well would have been near impossible for me. Thought so. Thanks Link to comment Share on other sites More sharing options...
JohnC3 Posted February 3 Share Posted February 3 Darn, I'm reasonably handy, but for some reason when I needed to replace mine (3 months in), I thought you would need to jack the frame. I took it to speedco and they charged me 100/bag to remove and install the new bags. Bracing the frame seems so obvious now. But I still didn't have the tools as I was full time newbe.😁 Live and learn! Link to comment Share on other sites More sharing options...
jegall Posted February 3 Share Posted February 3 I used two 20 ton jacks bought from Amazon Link to comment Share on other sites More sharing options...
Hypoxia Posted February 3 Share Posted February 3 (edited) I did a writeup along with photos of changing a 2007 Signature air springs several years ago. Google "S Series Air Bag AKA Air Spring Replacement I decided to make a document for reference for this forum as well as for my records, see attachment. S Series Air Bag AKA Air Spring Replacement.docx Edited February 3 by Hypoxia 1 Link to comment Share on other sites More sharing options...
