Turn signals
Has anyone had a problem with their turn signals and hazards just stop working.
I have a 2006 Monaco Dynasty Diamond iv and our last excursion the turn signals stopped working so I tried the hazards and they didn’t work either so I tested the flasher and didn’t have power going to it so I checked the turn signal switch and found no power there. Does it someway connect to the smart wheel module. Any body had this problem before.
Many times when you have a turn signal or tail light issue it's caused by the trailer tail light connector wiring.  Inside the rear electrical run box (just to the right of the engine) is a 3 to 2 wire tail light converter.  It is used to convert the separate tail light/turn signal on your coach to a combined tail light turn signal on a trailer.   Check this converter and the wiring down to the 7-way trailer tail light receptacle.
Edited by vito.a
  • 2 weeks later...
