SteveJ Posted June 3, 2020 Posted June 3, 2020 Hi (newbie to this Forum!) I have a build sheet for my 2004 HR Vacationer (I bought in 2018) that indicates I have (or should have) an Emerson Insta Hot ERV-AC installed. I have no literature for it, can't find anything on the internet about it and have no idea what I 'should' be looking for. I do have a second faucet next to the main faucet in the kitchen but that 'appears' to be for filtered drinking water. Never hot. Some owner before me may have removed it, I don't know. Don't even know if it was 120v/12v, something else or what it should look like. Any chance anyone still has literature (or at least pictures) of what it might look like? Thanks!!
Dr4Film Posted June 3, 2020 Posted June 3, 2020 That second faucet is for the Insta-hot. Probably not plugged in. Look under the kitchen cabinet to make sure it's connected. I removed mine and installed a soap pump for dishes.
James Selby Posted June 3, 2020 Posted June 3, 2020 I have a button on my kitchen lighting panel to turn the hot water dispenser heat on/off. Look under the sink to see if it has a tank, roughly the size of a coffee can.
Onthego Posted June 3, 2020 Posted June 3, 2020 Emerson & Insinkerator are the same here is a link to a owner manual https://insinkerator.emerson.com/documents/hot100-installation-care-use-manual-en-us-1567742.pdf
SteveJ Posted June 4, 2020 Author Posted June 4, 2020 Guess I will just have to 'punt' on this. My faucet looks nothing like the Emerson samples and there is nothing under the sink/faucet except for the 10gal hot water heater so either the build sheet is wrong or someone previous to me changed it out.
Dr4Film Posted June 4, 2020 Posted June 4, 2020 Have you traced any water lines FROM the unknown faucet on top as to where they go?
SteveJ Posted June 4, 2020 Author Posted June 4, 2020 Yes, I have traced the line and it just goes to the cold water line with room for a filter (actually the line has a tag on it that says "put filter here") so I certainly think that it is meant as a filtered water source (ie: drinking water) but I was hoping someone might have an ERV-AC manual so I could look for evidence of it somewhere in the coach but no one seems to have a picture/manual of that particular Insta-Hot. Thanks
Onthego Posted June 4, 2020 Posted June 4, 2020 If your model look like this it was only make a few years the tanks were make of plastic. Model HOT 1 https://www.manualslib.com/manual/909146/Insinkerator-Hot-1.html
georgecederholm Posted June 4, 2020 Posted June 4, 2020 4 hours ago, SteveJ said: Guess I will just have to 'punt' on this. My faucet looks nothing like the Emerson samples and there is nothing under the sink/faucet except for the 10gal hot water heater so either the build sheet is wrong or someone previous to me changed it out. Steve, it’s highly likely that it was just changed out. These units had a tendency to leak when they failed. Owners who had that happen generally only spent the $500 to replace if they actually used them. We didn’t. When ours failed, I did exactly what you describe: put a .5 micron Culligan filter under the sink and used the spigot for drinking water. Assuming the person who made the change wasn’t mighty PO’d, they probably left the 120VAC outlet and 12VDC switch that controls a relay for the outlet in place. That would allow you to put in a new one if you wanted. As an aside, I try to annotate my build sheet when I replace or remove something that’s on there. I’m not perfect at it, but I try so that, if we ever sell (more likely whoever inherits it after I pass), there is some kind of record. George C, 2005 Exec
Dr4Film Posted June 4, 2020 Posted June 4, 2020 1 hour ago, Onthego said: If your model look like this it was only make a few years the tanks were make of plastic. Model HOT 1 https://www.manualslib.com/manual/909146/Insinkerator-Hot-1.html That is the exact same model that was in my 2002 Monaco Windsor. Never used it from day one. So one day while staying in Tulsa OK on our way to Alaska I was changing out the kitchen faucet and decided to finally remove it. The old faucet and Insta-Hot went into the trash. The new faucet came with a soap dispenser so that's what went into the opening.
Ivan K Posted June 4, 2020 Posted June 4, 2020 Ours looks like this and still works and we use it all the time, just a few minutes to heat up and/or filtered cold water. It runs off the inverted power so I need to remember to turn it off when boondocking or the AGS will kick in. We find it very useful. Just got back from 6k miles of social distancing so cleaning is in order 😎
Chet P Posted June 5, 2020 Posted June 5, 2020 (edited) My insta-hot has a red thermal rest button on the side of the housing. When we got the coach, the reset was tripped and I had to reset the red overtemp button. Pressed the button and we had hot water. Ours is the same one as shown in the preceding post. Chet P 2004 SIG Castle IV. Edited June 5, 2020 by Chet P
