FunTripsUSA Posted March 11 Share Posted March 11 I have a 2003 Monaco Dynasty Diplomat and I have discovered that one of the three control fuse boards has had a short of some sort. Unfortunately the sticker that shows what all the fuses are for is gone. I called Monaco Coach however they do not have the records for my coach. I am hoping someone has the same set up we have. I found on this site another fuse diagram however the fuse amps are different from mine. Here is a link to what I found My Exhaust Brake is not working. Here are some pictures of my control board that has damage. I also so far cannot locate the wires that were cut from the harness. Link to comment Share on other sites More sharing options...
Dr4Film Posted March 11 Share Posted March 11 Ian, There is a file in the download area which has the wiring diagrams for a 2003 Monaco Dynasty. I would download that to your PC and peruse through that to see if you can find your answers. Wiring Diagrams - Bill D’s Monacoers Link to comment Share on other sites More sharing options...
DavidL Posted March 11 Share Posted March 11 I will guess that the wires to the right that have the solderless connectors used to plug into that burnt connector. Use the wiring diagram to be sure. Link to comment Share on other sites More sharing options...
FunTripsUSA Posted March 11 Author Share Posted March 11 Here are more photos Link to comment Share on other sites More sharing options...
Jdw12345 Posted March 11 Share Posted March 11 This must be a recent purchase I’m assuming! Can you contact the previous owner? Link to comment Share on other sites More sharing options...
Dr4Film Posted March 11 Share Posted March 11 (edited) Look for Fuse numbers F-20 through F-17 on the wiring diagrams once you find the correct fuse board. Edited March 11 by Dr4Film Link to comment Share on other sites More sharing options...
jacwjames Posted March 11 Share Posted March 11 Agree on the butt connectors as probably being the wires attached to the circuit board. You will have to get the wiring diagrams as Dr4Film suggested and try and decipher this out. Also take a close look at the wires, on my coach most of the wires actually were labeled as to what they were for. I was able to figure out what a couple unlabled relays in my front drivers side run bay. You might have to try and use a wire tracer to track the wires. Also, I looked at the inventory of Visione RV in KY, they have a 2003 Dynasty (fire damaged) but the front drivers side bay looked unscathed. You might call them and see if they have the board. The don't usually list specific boards but if that coach is still there I'm sure they'd get the board. Give them a call, if you actually talk to someone you might get lucky. The board itself can be removed fairly easy, all the wiring harness come off and the larger wires just come loose. Link to comment Share on other sites More sharing options...
FunTripsUSA Posted March 11 Author Share Posted March 11 47 minutes ago, DavidL said: I will guess that the wires to the right that have the solderless connectors used to plug into that burnt connector. Use the wiring diagram to be sure. The connector on the circuit board has 4 wires in the back of the hole. There are only 2 butt/solderless connectors to the right and those wires go down to a black box below the circuit board. 19 minutes ago, jacwjames said: Agree on the butt connectors as probably being the wires attached to the circuit board. You will have to get the wiring diagrams as Dr4Film suggested and try and decipher this out. Also take a close look at the wires, on my coach most of the wires actually were labeled as to what they were for. I was able to figure out what a couple unlabled relays in my front drivers side run bay. You might have to try and use a wire tracer to track the wires. Also, I looked at the inventory of Visione RV in KY, they have a 2003 Dynasty (fire damaged) but the front drivers side bay looked unscathed. You might call them and see if they have the board. The don't usually list specific boards but if that coach is still there I'm sure they'd get the board. Give them a call, if you actually talk to someone you might get lucky. The board itself can be removed fairly easy, all the wiring harness come off and the larger wires just come loose. Thank you. I messaged them this morning. I'll keep you posted. 58 minutes ago, Dr4Film said: Ian, There is a file in the download area which has the wiring diagrams for a 2003 Monaco Dynasty. I would download that to your PC and peruse through that to see if you can find your answers. Wiring Diagrams - Bill D’s Monacoers Truth to be told is I do not know how to read a wiring diagram. I did download the 2003 Dynasty wiring diagram. Thank you for the link. I will do my best to figure it out. Will the diagram show me the configuration of the circuit board? (meaning will is have a diagram of the circuit panel and fuse amps?) 36 minutes ago, Dr4Film said: Look for Fuse numbers F-20 through F-17 on the wiring diagrams once you find the correct fuse board. I found those numbers on the middle circuit board. I have a total of 3 circuit boards. Link to comment Share on other sites More sharing options...
Dr4Film Posted March 11 Share Posted March 11 25 minutes ago, FunTripsUSA said: Truth to be told is I do not know how to read a wiring diagram. I did download the 2003 Dynasty wiring diagram. Thank you for the link. I will do my best to figure it out. Will the diagram show me the configuration of the circuit board? (meaning will is have a diagram of the circuit panel and fuse amps?) I found those numbers on the middle circuit board. I have a total of 3 circuit boards. Look toward the end where it shows the circuit boards in the FRB. I think with some patience and process of elimination you will figure it out. Link to comment Share on other sites More sharing options...
FunTripsUSA Posted March 11 Author Share Posted March 11 8 minutes ago, Dr4Film said: Look toward the end where it shows the circuit boards in the FRB. I think with some patience and process of elimination you will figure it out. I found on page 204 of the 2003 Monaco Dynasty wiring diagram, with the link you provided, the three circuit boards. However my circuit board P/N does not match what is in the diagram. The part number on my coach is 16616257 and what is on the diagram is 16616143. Does that matter? I compared the fuses in my picture to the wiring diagram and they are in the same sequence. Link to comment Share on other sites More sharing options...
Dr4Film Posted March 11 Share Posted March 11 I would trust the diagram sequence versus the part numbers. Remember that this wiring diagram is for multiple coach models. Link to comment Share on other sites More sharing options...
FunTripsUSA Posted March 11 Author Share Posted March 11 4 minutes ago, FunTripsUSA said: I found on page 204 of the 2003 Monaco Dynasty wiring diagram, with the link you provided, the three circuit boards. However my circuit board P/N does not match what is in the diagram. The part number on my coach is 16616257 and what is on the diagram is 16616143. Does that matter? I compared the fuses in my picture to the wiring diagram and they are in the same sequence. page 183 does not match page 204. How do I decode this? Link to comment Share on other sites More sharing options...
DavidL Posted March 11 Share Posted March 11 (edited) I believe the difference in part numbers is if there is a heavy duty power feed to the board or not. I assume this is the board in question with the burnt connector. Engine Brake / Bag dump / Gauge Power / Backup (VIM) Those are the wires to track down to find out how this was "fixed" with a workaround so that the fuse block didn't have to be replaced. What is the black box at the bottom? Looks like it might be a relay. Might also be a fuse holder. Can't tell from the picture. Are your wires printed for function? Look back in the harness to find out what those wires are labeled that are solderless connected to the black "relay". Note that there was a short or loose connection or some other high amperage load for that connector to burn to begin with. Once the wires are found, the real root problem needs to be diagnosed. Edited March 11 by DavidL 1 Link to comment Share on other sites More sharing options...
Tom Cherry Posted March 11 Share Posted March 11 if you are referring to your owner's manual, there were always discrepancies as Monaco made runniing floor chanes and the assemblers never told the engineers and tech support group that wrote the manuals. your year isnot avalable online so i cant download and comment. fWIW, Monaco went bankrupt in 2009, but Navistar bought them and most of the tech support folks that knew the "Monaco products were rehired. As Navistar played around with the company, they realized they were in over their heads. REV bought it for the name and brand recognition. then, they closed all the factories and used the names and put them on existing Chassis. Your motorhome chassis and assembly died 10 years ago. REV has some prints....we may have more here. we have more tech support help than any REV peson....as they are lookin at prints and have no real concept of the 2003 Dynasty wiring concept. perhaps some 2003 owner can look in their manual. you will need to learn how to read prints and understand circuits....otherwise, find a good tech and make him your new best friend. 1 Link to comment Share on other sites More sharing options...
Ray Davis Posted March 11 Share Posted March 11 Ian, in this picture we can see the burned area and it looks to me like wires were cut off. Do you suppose the butt connectors are the same wires? If so, are they not protected by a fuse, any inline fuses nearby? On my Windsor, there is a removable black plastic cover that covers the wires & fuses. On the back side is the identification & location of fuses & etc. I suppose that cover is what you are missing. A missing cover has come up previously and someone with the same yr posted a picture of theirs. Not meaning to nitpick, but I think you misspoke saying " Dynasty Diplomat" . Link to comment Share on other sites More sharing options...
FunTripsUSA Posted March 11 Author Share Posted March 11 1 hour ago, Tom Cherry said: if you are referring to your owner's manual, there were always discrepancies as Monaco made runniing floor chanes and the assemblers never told the engineers and tech support group that wrote the manuals. your year isnot avalable online so i cant download and comment. fWIW, Monaco went bankrupt in 2009, but Navistar bought them and most of the tech support folks that knew the "Monaco products were rehired. As Navistar played around with the company, they realized they were in over their heads. REV bought it for the name and brand recognition. then, they closed all the factories and used the names and put them on existing Chassis. Your motorhome chassis and assembly died 10 years ago. REV has some prints....we may have more here. we have more tech support help than any REV peson....as they are lookin at prints and have no real concept of the 2003 Dynasty wiring concept. perhaps some 2003 owner can look in their manual. you will need to learn how to read prints and understand circuits....otherwise, find a good tech and make him your new best friend. What type of Tech would I be looking for? Do you know of any repair centers that may be able to help? Link to comment Share on other sites More sharing options...
DavidL Posted March 11 Share Posted March 11 4 minutes ago, FunTripsUSA said: What type of Tech would I be looking for? Do you know of any repair centers that may be able to help? A technician with moderate electrical skills is needed. That understands how to read a schematic and can use a Toner and Volt/Ohm meter. Link to comment Share on other sites More sharing options...
Tom Cherry Posted March 11 Share Posted March 11 4 minutes ago, FunTripsUSA said: What type of Tech would I be looking for? Do you know of any repair centers that may be able to help? this is the best help, remotely that i can give. you need an electronic tech that is familiar with the older Dynasties or the 2005 and older as the chassis wiring system was upgraded to a wole higher level in 2006. you should have let folks know where you are. i looked you up. you are near Tallahassee so that is a reference point. We have folks all over the USA GO TO THE PRINTS. The boar is the ACC & IGNITION BOARD. It is first referecned on the print called DYN/EXE/SIG AIR SEAL print. start scrollong down and the board and the 4 wire cpnnector appear in several prints. But there are somd prints where the 4 connector plug may or may NOT be connected to the 6 plug style that is used throughout. i didnt spend time on the 4 to 6 but you can. you have to read and understand. BUT. IMPORTANT...YOU OR TECH NEED TO LOOK HERE. Print is SIG/EXE/NAV J3 PLUG. Read the pins on the left. pin 8 is engine exhaust; pin 14 is bag dump; Pin 5 is prbably the Back up now....the next prints show how the wires get from this main plug to each of the pons or connectors. if you trace or tone out the brake and bag dump and back up....then you will eventually find a 4 wire bundle. if your back up lights work and your bag dump work, then someone cut the wires and put them somewhere else. WHY they didnt do the brake is a mystery. but if you have the exhaust brake wire, traced from J3, then finding a suitable fused alternative will be simple. now you know. sorry for the erratic caps, my left arm has a new joint and bound up in a combo sling and straight jacket 26 minutes ago, DavidL said: A technician with moderate electrical skills is needed. That understands how to read a schematic and can use a Toner and Volt/Ohm meter. based on the "configuration type of the prints, moderate is the minimum....these prints are Greek to most MH techs, unless they worked at a Monaco dealer. I can hold my own on the Camelots and do a little in the Dynasty. my mind dont work thgat way. LOL Link to comment Share on other sites More sharing options...
