bgfleck Posted March 12 Share Posted March 12 2007 Monaco Signature Series Noble III, ISX 600 89,700 miles $169,000 Top of the line Signature Series, pre-Def 600HP ISX. I have plenty more pics, and info that I can send you a link. 3 new AC/Heatpumps 2022 4 Lifeline 4D batteries 2021 2 Interstate Chassis batteries 2021 The pictures are from better weather. I will clean it up from the winter when we have some nice weekends. The black paint is checking, there is some peeling clearcoat. The coach is located in Louisville, KY. If you'd like a link to more pictures and information let me know. Link to comment Share on other sites More sharing options...
Rick A Posted March 12 Share Posted March 12 Nice looking unit. I’m sure it’s going fast! Good luck. Link to comment Share on other sites More sharing options...
Paul A. Posted March 13 Share Posted March 13 Does your coach have the Chassis Multiplex System? Would you please post a picture of the inside of the FRB? Thanks Link to comment Share on other sites More sharing options...
Frank McElroy Posted March 13 Share Posted March 13 3 hours ago, Paul A. said: Does your coach have the Chassis Multiplex System? Would you please post a picture of the inside of the FRB? Thanks A picture of the FRB will confirm but the pictures of the dash switches posted and the build sheet don't show this coach to be a chassis multiplex coach. Chassis multiplex coaches first came on model year 2008 sigs. Link to comment Share on other sites More sharing options...
bgfleck Posted March 13 Author Share Posted March 13 I don't have a picture on my phone, I will post a picture when I get home. Link to comment Share on other sites More sharing options...
Paul A. Posted March 13 Share Posted March 13 11 hours ago, Frank McElroy said: A picture of the FRB will confirm but the pictures of the dash switches posted and the build sheet don't show this coach to be a chassis multiplex coach. Chassis multiplex coaches first came on model year 2008 sigs. Thanks Frank. I do not, did not, see a picture of the dash switches posted. I did not know that Monaco Listed the Multiplex Chassis System on a Build Sheet. Would you post a picture of the Chassis Multiplex switch[s] used by Monaco. Does that apply to Holiday Rambler, Safari, and Beaver as well? Thank you. Link to comment Share on other sites More sharing options...
bgfleck Posted March 13 Author Share Posted March 13 Forgot I could access Google Drive from my phone. Link to comment Share on other sites More sharing options...
Frank McElroy Posted March 13 Share Posted March 13 1 hour ago, Paul A. said: Thanks Frank. I do not, did not, see a picture of the dash switches posted. I did not know that Monaco Listed the Multiplex Chassis System on a Build Sheet. Would you post a picture of the Chassis Multiplex switch[s] used by Monaco. Does that apply to Holiday Rambler, Safari, and Beaver as well? Thank you. One of the pictures posted by Brian showed dash switches on the center console (hard to see but I could make them out). They were conventional. Chassis multiplex dash switch come only in a 3 switch modules. I attached an example module used by Monaco. I don't know about Holiday Rambler and Safari, but yes, high end Beaver coaches had the same chassis multiplex system as Monaco. The built sheet will also list the Megadyne Teleflex Chassis Multiplex system as standard equipment. Link to comment Share on other sites More sharing options...
bgfleck Posted March 13 Author Share Posted March 13 (edited) Our switches are standard Carling switches. House is Multiplex and chassis is standard Carling switches Edited March 13 by bgfleck Link to comment Share on other sites More sharing options...
Tom Cherry Posted March 13 Share Posted March 13 because you do not have the CCM. They are unique and are in a gang of three and there are at least 8 gangs or maybe 10. you do not have the CCM Module in the FRB as that was not the standard in 2007. Link to comment Share on other sites More sharing options...
Rick A Posted March 13 Share Posted March 13 Is there a list of Acronyms for all the terms being used? That would help a lot. If there isn’t maybe I should try and put one together in the watchful eye of the experts . 2 Link to comment Share on other sites More sharing options...
Paul A. Posted March 13 Share Posted March 13 4 hours ago, Frank McElroy said: One of the pictures posted by Brian showed dash switches on the center console (hard to see but I could make them out). They were conventional. Chassis multiplex dash switch come only in a 3 switch modules. I attached an example module used by Monaco. I don't know about Holiday Rambler and Safari, but yes, high end Beaver coaches had the same chassis multiplex system as Monaco. The built sheet will also list the Megadyne Teleflex Chassis Multiplex system as standard equipment. Thank you Frank. 4 hours ago, bgfleck said: Our switches are standard Carling switches. House is Multiplex and chassis is standard Carling switches Thank you Brian. Link to comment Share on other sites More sharing options...
