daveyjo Posted March 31, 2023 Share Posted March 31, 2023 My Aria toilet opens fine, and even closes fine, but squeaks as it closes. I put Vaseline on the sliding valve but it made no difference. Anyone have some experience with this issue? Dave Jones 2005 HR Scepter Link to comment Share on other sites More sharing options...
jacwjames Posted March 31, 2023 Share Posted March 31, 2023 The blade is moved in and out by a motor on a threaded shaft with gears. I've taken mine apart and put some grease on it. Link to comment Share on other sites More sharing options...
OhReally Posted April 1, 2023 Share Posted April 1, 2023 As Jim said above but be sure to use silicone grease. It's waterproof and available at any Lowe's or home Depot. Use on the blade also instead of the Vaseline which doesn't last. Link to comment Share on other sites More sharing options...
Bill C Posted April 1, 2023 Share Posted April 1, 2023 I have the same toilet. I always thought that the squeaky sound was from the moving rubber flap, sticking" a little on the sides of the slot that it goes in to. I have tried many suggestions from people, including Vaseline, white silicone grease, WD-40, etc. and I think the most affective was the Vaseline. Some will say that the Vaseline ingredients will hurt the rubber, but who knows. I consider the noise more of a nuisance than the rubber concern. Bill Link to comment Share on other sites More sharing options...
daveyjo Posted April 6, 2023 Author Share Posted April 6, 2023 I tried Vasoline and it didn't work. Then I tried it again but using a brush to reach well into the blade groove and that seemed to work. Haven't got any silicone grease yet to try next. Thanks for the feedback. Dave Jones Link to comment Share on other sites More sharing options...
daveyjo Posted April 14, 2023 Author Share Posted April 14, 2023 On 4/1/2023 at 3:08 PM, OhReally said: As Jim said above but be sure to use silicone grease. It's waterproof and available at any Lowe's or home Depot. Use on the blade also instead of the Vaseline which doesn't last. Both tries with Vaseline failed very quickly. The silicone grease has worked quite well for several days. I wasn't familiar with silicon grease, but found some at Ace hardware in the plumbing supply area. Apparently it is used in plumbing applications where there is water (like lubricating a faucet) involved. Great advice, thanks for the responses. Link to comment Share on other sites More sharing options...
