Chuck H Posted April 22, 2023 Share Posted April 22, 2023 I'm pretty green on using this site but slowly learning so please bear with me. I was changing out a cooktop burner on/off valve so I thought I should probably try to turn off the main propane valve at the tank as a precaution. Could not find a traditional looking valve similar to what I thought would look like a typical patio BBQ tank valve knob. There is one on the curbside of the tank but there are no gas lines connected to it. The only valve that had any lines to it is the one in the attached pic. So I tried to close it and was a little hard to turn also turned off the round switch next to the red light which is apparently burned out. Finished my cooktop burner on/off valve replacement, opened valve back up(again hard to turn) turned on round switch went inside and tested burner valve and everything worked fine. Yahoo another project completed. Went back underneath to the tank and decided to check that little valve with some soapy solution and sure enough it was leaking, couldn't smell anything but was definitely bubbling. Now I have no idea which way to turn so any ideas would be greatly appreciated... Link to comment Share on other sites More sharing options...
Solution CLIFF918 Posted April 22, 2023 Solution Share Posted April 22, 2023 Chuck, I think that is not a valve. Might be pressure relief. My 02 Diplomat has only the electric valve for turning off the tank. That’s the one next to the light. Try tapping that relief with something, you might get it to reseat if not it should be replaced. 1 Link to comment Share on other sites More sharing options...
Chuck H Posted April 22, 2023 Author Share Posted April 22, 2023 That would explain why I couldn't find an actual shutoff valve because this coach I think is also only electrically turned off & on. I will give that a try. Thanks Cliff Link to comment Share on other sites More sharing options...
Floyd4949 Posted April 24, 2023 Share Posted April 24, 2023 On 4/22/2023 at 4:05 PM, Chuck H said: ...the red light which is apparently burned out https://www.grainger.com/product/20C840?RIID=65937569715&GID=&mid=OpenOrders_WillCall&gucid=EMT:10101010:SKU:CSM-348&emcid=NA:SKU Link to comment Share on other sites More sharing options...
Chuck H Posted April 24, 2023 Author Share Posted April 24, 2023 Perfect John, I'll get one ordered. Thank you for the website. Link to comment Share on other sites More sharing options...
