Slide out not retracting
Guest INDY DIXONS
Guest INDY DIXONS
03 Signature Commander, opened all slides and the front passenger slide will not retract. We don't have the manual with us
therefore, can't check it.  It does have a new switch, what might the solution be?  TIA
I assume it is a hydraulic slide. Do you hear the pump motor run when trying to retract? The same pump would operate your generator slide, does that work?
It won't work if the contact pins on basement doors under the slide are open or with ignition on, at least on ours.
Since you appear to have internet access, you can download 2002 or 2004 manual. For what ever reason, there isn't one for 2003 but I doubt it would be much different.
https://www.monacocoach.com/resources/media/manuals/2002_Signature.pdf
