TommyL Posted May 11, 2023 Share Posted May 11, 2023 08 Camelot ISL 400 side radiator, thinking about trying to add vents to exterior engine hatch to let some heat out. Rear bath and closet gets really warm. Not bad in winter, preheated toilet seat and shower. Summer’s a little different. Anyone have a DIY suggestion or pictures of your modifications Thanks , Tommy & Cheri , Eufaula Ok. Link to comment Share on other sites More sharing options...
timaz996 Posted May 11, 2023 Share Posted May 11, 2023 (edited) I did this mode in late 2017 because my 120v wire loom goes up through the front of the engine compartment to the circuit box and would pop A/C breakers in the summer while driving. (Phoenix) My brother made these brackets for me. They hold the engine lid open about 8". I'm sure it also keeps the alternator cooler also. Another plus is the bedroom stays cool after driving all day. Edited May 11, 2023 by timaz996 added text Link to comment Share on other sites More sharing options...
96 EVO Posted May 11, 2023 Share Posted May 11, 2023 Biggest difference I've found between the '08 Camelot, and '08 HR Scepter, is the rear cap design! The Scepter has a large opening above the engine hatch to allow heat out! There is a couple I know of that installed venting into their Camelot cover. Hopefully they will see this thread. Link to comment Share on other sites More sharing options...
Ivan K Posted May 11, 2023 Share Posted May 11, 2023 I like your solution for the hot days. Can you show how are the adapters actually mounted? I would still like to keep the ladder in place for the pole mount so I would be limited to no more than 3" stand off. Too late for me now since we are already in AZ but maybe next time. Link to comment Share on other sites More sharing options...
Tom Cherry Posted May 11, 2023 Share Posted May 11, 2023 Start googling. https://www.irv2.com/forums/f115/camelot-rear-cap-vent-source-364839.html I used Monaco Camelot rear cover heat there was a factory fix for this with a custom (SS or black anodized) grill….maybe 2 with a circulation fan inside the engine compartment. Thermostatic control in the top of the engine compartment and a exhaust fan. Some have had CB pop. There was a bunch of stuff out there. Try different google topics. Fortunately, they revised the rear deck…..when? The 09 Camelot have a top vented louver (molded in). That helps….but a buddy with a 42 said that the engine latches would melt a thin plastic dry cleaning plastic clothes cover. I run the Genny and both AC and that helps… Link to comment Share on other sites More sharing options...
timaz996 Posted May 11, 2023 Share Posted May 11, 2023 3 hours ago, Tom Cherry said: Start googling. https://www.irv2.com/forums/f115/camelot-rear-cap-vent-source-364839.html I used Monaco Camelot rear cover heat there was a factory fix for this with a custom (SS or black anodized) grill….maybe 2 with a circulation fan inside the engine compartment. Thermostatic control in the top of the engine compartment and a exhaust fan. Some have had CB pop. There was a bunch of stuff out there. Try different google topics. Fortunately, they revised the rear deck…..when? The 09 Camelot have a top vented louver (molded in). That helps….but a buddy with a 42 said that the engine latches would melt a thin plastic dry cleaning plastic clothes cover. I run the Genny and both AC and that helps… I didn't want to cut a hole in the lid. 3 hours ago, Ivan K said: I like your solution for the hot days. Can you show how are the adapters actually mounted? I would still like to keep the ladder in place for the pole mount so I would be limited to no more than 3" stand off. Too late for me now since we are already in AZ but maybe next time. Here’s a picture Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted May 11, 2023 Share Posted May 11, 2023 Could you leave the engine hatch open? Might not look so good but should let the heat out. Link to comment Share on other sites More sharing options...
Ivan K Posted May 12, 2023 Share Posted May 12, 2023 Thanks Tim, I won't be cutting any holes either. Link to comment Share on other sites More sharing options...
timaz996 Posted May 12, 2023 Share Posted May 12, 2023 This option lets out so much more air I know your engine will run cooler and the bedroom won't be warm at the end of a travel day. 1 Link to comment Share on other sites More sharing options...
96 EVO Posted May 12, 2023 Share Posted May 12, 2023 51 minutes ago, Ivan K said: Thanks Tim, I won't be cutting any holes either. Your engine compartment is sealed up tight as well? Link to comment Share on other sites More sharing options...
Ivan K Posted May 12, 2023 Share Posted May 12, 2023 3 minutes ago, 96 EVO said: Your engine compartment is sealed up tight as well? Not totally tight but more air could not hurt. I had a 190F temp/fire sensor there to trigger an alarm and it did. Link to comment Share on other sites More sharing options...
96 EVO Posted May 12, 2023 Share Posted May 12, 2023 (edited) I'll post that same view of mine tomorrow. I've probably got an 8" opening there! Ok, I lied! It's only about 6"..... I was also sure my 'you know what' was 8" 😁! Edited May 12, 2023 by 96 EVO 1 Link to comment Share on other sites More sharing options...
