Woody O Posted May 13, 2023 Share Posted May 13, 2023 While backing into campsite with lift axle raised, the switch light went off and the axle went back down. So, Im thinking I blew a fuse. I looked at tech pages to see if they could help me. No luck. Can't find fuse. I see some lift axle relays in front run box. So, is my next task checking the relays to see if need replacing? Link to comment Share on other sites More sharing options...
Woody O Posted May 15, 2023 Author Share Posted May 15, 2023 On 5/13/2023 at 10:25 AM, Woody O said: While backing into campsite with lift axle raised, the switch light went off and the axle went back down. So, Im thinking I blew a fuse. I looked at tech pages to see if they could help me. No luck. Can't find fuse. I see some lift axle relays in front run box. So, is my next task checking the relays to see if need replacing? So, left campsite and returned home and the lift axle works like it is suppose to. I have no ideal as to why it stopped working while backing into site but glad it is working fine now. Link to comment Share on other sites More sharing options...
Ivylog Posted May 15, 2023 Share Posted May 15, 2023 About the only time I raise my tag is when changing the tires. Link to comment Share on other sites More sharing options...
