andykim Posted May 23, 2023 Share Posted May 23, 2023 No water thur city connection into coach, assuming check valve stuck, replace or try to repair?, how bad to replace? Link to comment Share on other sites More sharing options...
Garry Donohue Posted May 23, 2023 Share Posted May 23, 2023 Do you have a button to push to switch between city fill and fresh water tank fill? Then if you have the Aladdin system, you must turn on Aladdin to activate switch. Link to comment Share on other sites More sharing options...
andykim Posted May 23, 2023 Author Share Posted May 23, 2023 No push buttons, no Aladdin system, just ball valves, city valve is open, filled h2o tank thru exterior fill, turned on city ball valve no flow to sink or shower, tank water system works with pump no problem to all devices Link to comment Share on other sites More sharing options...
Ivan K Posted May 23, 2023 Share Posted May 23, 2023 I had the same happen a couple of weeks ago. The shore inlet check valve plunger separated from its spring and just plugged the opening. I removed it, gutted the insides and reinstalled since it still had to serve as a connecting fitting. Had to take the cover off to get to it so it depends where yours is. Link to comment Share on other sites More sharing options...
KevinH Posted May 23, 2023 Share Posted May 23, 2023 I had that problem when I first purchased our coach. My fill hose had a pressure reducing valve that was faulty. I took it off and everything worked. Link to comment Share on other sites More sharing options...
