David White Posted June 19, 2020 Share Posted June 19, 2020 My ‘05 Windsor does not have an alarm or alert to tell me my lights are on when the ignition switch is off, and I’m not sure if it ever had one since I’ve owned it for 12 years without an getting an alarm. Can anyone tell me if one should be on the MH, what the problem might be, and where it is located? If not, what can I do to add one? Link to comment Share on other sites More sharing options...
windsorbill06 Posted June 19, 2020 Share Posted June 19, 2020 David, Not sure if your 05 has a dash annunciator box, but mine is under the front dash. When my headlights are on, it's a fairly rapid 'chirp'. I've read that some have had issues with it and took the box apart and repaired a small speaker inside. 1 Link to comment Share on other sites More sharing options...
David White Posted June 19, 2020 Author Share Posted June 19, 2020 Thanks Bill, I’ll check but I’ve never seen one under my dash. I’m assuming it handles all the alarms and my others are working. The headlight one could be disconnected. Link to comment Share on other sites More sharing options...
windsordst Posted June 19, 2020 Share Posted June 19, 2020 Good day to you. My 04 Windsor has no indication buzzer for lights on and ignition off. Never caused a problem. Respectfully Stuart Link to comment Share on other sites More sharing options...
windsorbill06 Posted June 19, 2020 Share Posted June 19, 2020 2 hours ago, David White said: Thanks Bill, I’ll check but I’ve never seen one under my dash. I’m assuming it handles all the alarms and my others are working. The headlight one could be disconnected. Yes, it's buried in the mass of wiring under the dash. Possibly turn on one of the other chimes and track down the sound. But like Stuart mentions, his 04 doesn't have the buzzer either. Good luck! Link to comment Share on other sites More sharing options...
