tomfreeman56 Posted June 23, 2020 Share Posted June 23, 2020 I have a 2006 HR Navigator 45. We have had it parked for a few months with the battery kill switches off. Upon going to get it today in preparation of a trip with our grandson this week, I discovered that the shore power to the coach had accidentally been turned off and the 2 AGM chassis batteries and the 4 AGM coach batteries were completely drained and dead. These were replaced and everything works except for the HWH leveling systems. Nothing will light up on the touch panel on the driver's arm rest . There is no power to the HWH control module in the front generator bay (or no lights on the circuit board and fuses). The master warning light and the reset switch in the roadside fuse bay are not lit. I have done the following in an attempt to get the system working: - Replaced the in-line fuses on the batteries in the battery bay. - Replaced any fuse the was labeled LVL in the front roadside fuse bay. They are lit. - Checked the rear fuse panel in the engine compartment. - Parking brake is working and lit on the dash board. - Coach is in Neutral. - Slides work. - Air system has 100-125psi showing on the dash gauges, when coach is running. The HWH system is Model # AP30514/45-Jll AR/E I'm not sure what to check now. I have called the HWH Tech support, but they are running days behind, so I'm waiting for a call back from them. I do not want to move the unit without the airbags leveling. If anyone has any suggestions, I would appreciate them. If nothing else, does anyone know of a mobile repair tech in the Aberdeen/Fayetteville, NC area? Thanks. Tom and Cynthia Freeman 2006 HR Navigator 45PBQ Link to comment Share on other sites More sharing options...
Bruce B Posted June 23, 2020 Share Posted June 23, 2020 I had something similar on a ‘04 Signature. For me the board in the left front run box had lost power to the HWH. A Tech ran power from one side of the board to the other and it worked. I now carry a spare board. Why this happened I have no idea. Good luck, I’m sure you will find the issue. Link to comment Share on other sites More sharing options...
Steven P Posted June 29, 2020 Share Posted June 29, 2020 I would double and triple check all battery connections. Since all those batteries were replaced, maybe something wasn't hooked up right? Link to comment Share on other sites More sharing options...
granvillebarker Posted August 5, 2020 Share Posted August 5, 2020 (edited) I had trouble with my HWH power, the unit was getting power but not coming on. HWH wanted allot for a new unit; I took it to an electronics friend that found a bad Power diode On the board, replaced it for .20 cents and back going. Edited August 5, 2020 by granvillebarker Link to comment Share on other sites More sharing options...
David Pratt Posted August 5, 2020 Share Posted August 5, 2020 Tom In the FRB on the bottom left side are four circuit boards that are grouped together that all look the same.The boards are numbered left to right. The top two boards are left board is 14 and the board to the right is 12. The bottom two boards are left board is 15 and the board to the right is 13. On the bottom of board 13 on the lower right side there is a 10 or 12 Gauge white wire with a push on blade connector that is plugged into the bottom of the board and just above it is the fuse for the HWH Leveling system. That white wire is the power B+ lead that powers up the HWH computers. Check the fuse above it and also remove and reinstall the push on white wire and hopefully it will fix your problem. Also, when your HWH leveling System fails. When you start your coach and release the park brake and put the coach in gear, the coach will automatically go to ride height. That is the factory default setting for when the HWH Leveling System is inop. Let us know how it works out. Link to comment Share on other sites More sharing options...
granvillebarker Posted August 6, 2020 Share Posted August 6, 2020 I was just looking at my HWH notes, and noticed there’s a hidden fuse in the D/S armrest, it says look for Plug #43A. I have a 2005 Dynasty, but it’s likely you may have the same fuse. Link to comment Share on other sites More sharing options...
Hotrod Posted August 6, 2020 Share Posted August 6, 2020 If there are no lights on the computer, it isn’t getting any power. David Pratt’s info sounds accurate. I have the same front run box in my 06 Dynasty. A couple of the 30a relays on the boards David mentions have gone bad over the years and supply power to the various systems . One is the Hwh, another the Vorad system and so on. Unfortunately the Relays are soldered onto the board. They can be repaired with care. Anyway , with a voltmeter you can check for power there . There is one relay on the hwh computer that is normally open and gates ignition to the travel valves , so if the computer is off and not getting power, that relay is open and the ignition signal goes to the travel valves. So with the ignition switch on, check to see if you are at ride height . You should be good to go. It sounds like a front run box, power for the Hwh, issue to me to. Link to comment Share on other sites More sharing options...
tomfreeman56 Posted August 9, 2020 Author Share Posted August 9, 2020 Thanks all. I have had 2 techs troubleshoot the system and found one in OKC that seems to know what he is doing. The problem seems to be in one of the 3 circuit boards. I have 1 in the FRB and 2 under the livingroom slideout, hidden under the floor, accessible from a storage bay under the slide out. The tech worked with HWH on trouble shooting until it was narrowed down to the slideout board. HWH said it was unusual that it was there but Monaco did what they wanted with the HWH boards. On the 3rd board there is a fuse that keeps blowing and it looks like on the board that there is a damaged diode or relay that can only be accessed by pulling both boards. In my next trip to OKC in the Fall I will have the tech pull the boards and we can see what is going on. If not HWH said to send them the boards and they would troubleshoot. Hopefully the extended warranty will cover the costs. I did check for a fuse in the D/S armrest but nothing there, I will wait until we are back in town and then have the work done. Airbags inflate for travel, I just can't use them to level, so I'm using the hydraulic jacks. Link to comment Share on other sites More sharing options...
Mark Ogier Posted September 24, 2020 Share Posted September 24, 2020 (edited) I have a 2003 Holiday Rambler, I have no power to the HWH touch pad, the travel light does illuminate. I found the control box and the 15 amp Battery fuse was blown, I replaced the fuse, but still no power on the touch pad, Park brake set and trans in neutral. Any help would be much appreciated as I called HWH and their tech support return call list is end of the year! Edited September 24, 2020 by Mark Ogier Link to comment Share on other sites More sharing options...
granvillebarker Posted September 24, 2020 Share Posted September 24, 2020 Did the fuse blow again after you replaced it? Does yours have a reset switch and warning light in the front run bay? Link to comment Share on other sites More sharing options...
Mark Ogier Posted September 24, 2020 Share Posted September 24, 2020 The fuse did not blow, wasn't aware of a reset switch and light, I'll check it out this evening, my control box is located in the top of the mid bay, that took awhile to find, Thanks Link to comment Share on other sites More sharing options...
Mark Ogier Posted September 24, 2020 Share Posted September 24, 2020 Hey granvillebarker, I can't find a reset switch or light, nothing in front run bay or where the control box is located, this is a 600 series system, any other ideas? Link to comment Share on other sites More sharing options...
Ivan K Posted September 24, 2020 Share Posted September 24, 2020 Our HWH does not have a reset switch either. When you were inside the controller box, have you checked or reseated the cable to touchpad? Ours got loose on both sides of it over time and caused leveling to not function similar to yours. But never blew a fuse. Link to comment Share on other sites More sharing options...
granvillebarker Posted September 24, 2020 Share Posted September 24, 2020 Is the unit in the top of the bay getting power? Are any LED’s on? I think the ignition may need to be on. Link to comment Share on other sites More sharing options...
Mark Ogier Posted September 24, 2020 Share Posted September 24, 2020 Thanks Ivan K, I did pull the cable to touch pad and re-seat, granvillebarker, there are no LED's on any of the two boards in the control box. I will verify there is power on the cable going to the control box this evening, thank y'all for you help! Link to comment Share on other sites More sharing options...
Bruce B Posted September 24, 2020 Share Posted September 24, 2020 I had something similar in a 2004 Signature, it turned-out to be a cracked solder on the board that powered the HWH in the LF box, mine was upper left. Power was not going across the board to the fuse, an RV Electrician ran power from the 'powered' side of the board to the non 'powered' side, it worked for me. I bought a new board and will install it when I have time or when the 'fix' stops. Check to see if you are getting power to those fuses. Link to comment Share on other sites More sharing options...
Mark Ogier Posted September 28, 2020 Share Posted September 28, 2020 Thanks for everyone's help, I contacted HWH thru email and they responded very quick. My power supply board seems to be the problem, something shorted to ground. 1 Link to comment Share on other sites More sharing options...
