Cayman51 Posted September 11 Share Posted September 11 Hi to the greater knowledge. our 06 cayman 36PDQ has decided to not start. The starter motor is good and have good voltage throughout the bus, the ignition switch is also good. I’ve checked all fuse and relay’s I can find but am stumped why she won’t go. Any ideas? Mike Link to comment Share on other sites More sharing options...
Doug and Nicki Posted September 11 Share Posted September 11 Are you getting good engine rotation with the starter? Slow turnover is a problem for diesels. Link to comment Share on other sites More sharing options...
Cayman51 Posted September 11 Author Share Posted September 11 hi guys, if I bridge the starter motor it turns no problem, just nothing on the key. there's a feed coming from the ignition key but it just doesn't make it the rear. been at it for 2 days and don't seem to be getting anywhere. were full time aswell. mike Link to comment Share on other sites More sharing options...
Ivan K Posted September 11 Share Posted September 11 Do you have wiring diagrams? The start signal from key switch should go through trasmission neutral lockout relay and possibly an other start solenoid before making it to the starter solenoid. Link to comment Share on other sites More sharing options...
timaz996 Posted September 11 Share Posted September 11 (edited) Mike, if you have a rear start switch in the engine compartment try starting the coach from there with the ignition key on. I had the same problem as you are dealing with now and it was the front/rear switch in the engine compartment. That was the problem. Edited September 11 by timaz996 Link to comment Share on other sites More sharing options...
Cayman51 Posted September 11 Author Share Posted September 11 Does anyone know where the neutral lockout relay is ? wiring diagram says front distribution box but can’t see it? Don’t have rear engine start , but thanks for that idea Link to comment Share on other sites More sharing options...
Ivan K Posted September 11 Share Posted September 11 48 minutes ago, Cayman51 said: Does anyone know where the neutral lockout relay is ? wiring diagram says front distribution box but can’t Typically it should be just like any other automotive bosh relay but I can't tell you where. I would guess you have a bunch of them there up front (but mine is in the engine room near a smaller start solenoid), could you possibly trace it by wire color from the diagram? Link to comment Share on other sites More sharing options...
timaz996 Posted September 11 Share Posted September 11 (edited) This is where mine is at. Top row of relays, third from the right across from top. Edited September 11 by timaz996 added text Link to comment Share on other sites More sharing options...
Cayman51 Posted September 11 Author Share Posted September 11 Thank Tim, mines a lot different from yours, but it does give me some ideas Link to comment Share on other sites More sharing options...
Gary Cole Posted September 12 Share Posted September 12 You likely have a parking brake interlock relay. It's near the parking brake air valve. Link to comment Share on other sites More sharing options...
Cayman51 Posted September 12 Author Share Posted September 12 I’ll check it out,thanks Link to comment Share on other sites More sharing options...
Robert92867 Posted September 12 Share Posted September 12 iRV2 Forums > RV SYSTEMS AND TECHNOLOGIES FORUMS > RV Systems & Appliances 2007 5.9L Cummins Fault Code Link to comment Share on other sites More sharing options...
Cayman51 Posted September 12 Author Share Posted September 12 Hi guys , thanks for all the suggestions and ideas of what to try, but I found the problem. Turns out I had four broken crimp connections hidden in the engine bay, all sorted now😀🤪 Link to comment Share on other sites More sharing options...
