Guest Tim503 Posted July 7, 2020 Share Posted July 7, 2020 If you stay with 4 T105 type and the original set up I would just use the electronics with fridge and maybe the microwave for a minute. Otherwise you should start the generator. Your lights are most likely 12 volt. You can add another 2/0 if need be but your batteries should not be used for a long microwave use. Short plate or coffee heating is okay. The remote will give you it's voltage. Link to comment Share on other sites More sharing options...
