RVingShawn Posted July 14, 2020 Share Posted July 14, 2020 I have the factory option for the drop down tv in the passenger side front slide out. At this time, it is refusing to go up when I press the switch, which also means I cannot bring the slide in. I believe I have diagnosed the issue to be a small plastic gear (of sorts) in the lift mechanism that is out of alignment. I'm not sure if I can realign it or if it needs replaced. Does anyone have any suggestions/know where I can find replacement parts? Thanks Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted July 14, 2020 Share Posted July 14, 2020 Have you checked the parts list? Link to comment Share on other sites More sharing options...
RVingShawn Posted July 14, 2020 Author Share Posted July 14, 2020 Where do I find that? It took me quite some time to find any kind of manual on the system. I just purchased this coach less than one month ago. Link to comment Share on other sites More sharing options...
Xlr8ting1 Posted July 14, 2020 Share Posted July 14, 2020 On my "09 Dynasty the outside tv lift was from a company in Seattle, WA. called Lift It Inc. Their web site http://www.liftmytv.com They produced both flip down and drop down tv slides. From the web site it sounds like they only carry a minimal amount of parts and no longer build these units. I have had the same issues years ago with a broken tooth on the track causing misalignment. You might have to consider a retrofit from another company. Look at Smith Richards Inc. I have not had any experience with them but found them on one of my searches. Xlr8ting1 09' Dynasty Link to comment Share on other sites More sharing options...
RVingShawn Posted July 14, 2020 Author Share Posted July 14, 2020 29 minutes ago, Xlr8ting1 said: On my "09 Dynasty the outside tv lift was from a company in Seattle, WA. called Lift It Inc. Their web site http://www.liftmytv.com They produced both flip down and drop down tv slides. From the web site it sounds like they only carry a minimal amount of parts and no longer build these units. I have had the same issues years ago with a broken tooth on the track causing misalignment. You might have to consider a retrofit from another company. Look at Smith Richards Inc. I have not had any experience with them but found them on one of my searches. Xlr8ting1 09' Dynasty Thank you very kindly for the suggestion. I just reached out to Smith Richards Inc. to inquire if that is something they could handle. Thank you! Link to comment Share on other sites More sharing options...
RVingShawn Posted March 17, 2022 Author Share Posted March 17, 2022 Update on this. By a miracle, was able to locate a "new" (not newly built but had never been installed) lift from Lift It. Had it installed and suffered a new failure. Where as this unit is now mechanically sound, the computer module for it is problematic. It appears to have a part number of LI-IES-D-701 with a possible prefix of 2 26 08. I am now searching high and low to find a replacement module, although my initial looking has brought up nothing. Any suggestions on where to look would be greatly appreciated. Shawn Link to comment Share on other sites More sharing options...
