Jim McGarvie Posted August 24, 2024 Posted August 24, 2024 Our 2002 Knight (built in 2001) has an Allison 1000 cooled by a side radiator with an electric fan. How is the fan controlled? Is there a thermostat? I tried turning the ignition on and listening by the cooler but did not hear a fan. Is there any way of testing the fan?
Solution Idoc57 Posted August 25, 2024 Solution Posted August 25, 2024 16 hours ago, Jim McGarvie said: Our 2002 Knight (built in 2001) has an Allison 1000 cooled by a side radiator with an electric fan. How is the fan controlled? Is there a thermostat? I tried turning the ignition on and listening by the cooler but did not hear a fan. Is there any way of testing the fan? Jim, Does your coach have any kind of radiator at the back? If it does, I would wonder if that radiator on the side might be the A/C condenser. If there is a radiator in the back, crank the engine up and turn on the dash A/C. Check to see if that fan comes on. Carey 1
Jim McGarvie Posted August 25, 2024 Author Posted August 25, 2024 2 hours ago, Idoc57 said: Jim, Does your coach have any kind of radiator at the back? If it does, I would wonder if that radiator on the side might be the A/C condenser. If there is a radiator in the back, crank the engine up and turn on the dash A/C. Check to see if that fan comes on. Carey I bet you're right. Come to think of it, it has three heat exchangers in the back. Engine radiator, CAC, and probably transmission cooler. Duh. We've only had this coach 23 years. I will check it out. Thanks Carey! 1
Jim McGarvie Posted August 25, 2024 Author Posted August 25, 2024 Carey, I checked as you suggested and that is definitely the dash A/C condenser. And the fan is working. Thanks!
georgecederholm Posted August 26, 2024 Posted August 26, 2024 22 hours ago, Jim McGarvie said: I bet you're right. Come to think of it, it has three heat exchangers in the back. Engine radiator, CAC, and probably transmission cooler. Duh. We've only had this coach 23 years. I will check it out. Thanks Carey! Jim, I think I remember a variety of discussions over the years about early-2000s rear radiator (not sure about side radiators) setups having the transmission cooler built into the radiator itself, with the engine coolant, CAC, and engine oil being the three radiators in the stack. The issues arose when cross-contamination occurred, I think engine coolant getting in the transmission fluid. As long as you monitor these fluids regularly, you should be fine, especially after 23 years! 1
