Bert Garcia Posted September 14, 2022 Share Posted September 14, 2022 My original Voyager dashboard display model AOM-7694 failed. I replaced it with a Voyager model VOM719WP said to be a direct replacement as the AOM-7694 is no longer available. All three cameras work correctly on the display. However, the Aladdin does not display properly. It flashes on the display briefly and intermittently. The video mode in the menu is NTSC. Since the cameras display properly and the Aladdin is seen briefly, I assume the wiring is correct. Can someone help me get the Aladdin to display properly? Thanks! Link to comment Share on other sites More sharing options...
bradc344 Posted September 14, 2022 Share Posted September 14, 2022 Hi. I would call Tim at RVCams he is very helpful. BRad Link to comment Share on other sites More sharing options...
Solution Bert Garcia Posted September 20, 2022 Author Solution Share Posted September 20, 2022 Problem solved. The Voyager model VOM719WP monitor will not work with the Aladdin. Bought another monitor that accepts composite video and placed it on the dashboard. Everything work correctly now. Link to comment Share on other sites More sharing options...
SteveK1 Posted May 17 Share Posted May 17 Hi Bert, i know it has been awhile since your post but I am need to replace my monitor and don’t want to lose my Aladdin features. Can you tell me what monitor you found that allowed you to maintain your features? Link to comment Share on other sites More sharing options...
bradc344 Posted May 18 Share Posted May 18 I replaced everything from Tim at rv cams great knowledge and help he can answer all your questions Link to comment Share on other sites More sharing options...
