jreich888 Posted May 5, 2021 Share Posted May 5, 2021 Hi, the backup camera and Triptek 2500 information display on our 03 Windsor has become flakey and/or failed. The monitor itself seems fine (can display other composite video source on the screen, but the cannot get the camera / info display to work reliably (neither on the dash monitor nor on separate monitor). Every once in a while the monitor and the info display will work, but rarely for more than a minute. I've looks for wiring breaks, bad connectors, tightened up ground connections, opened the triptek and looked for burns, but nothing obvious. Has anyone debugged the Triptek units, or had a similar problem? Any other advice here? Link to comment Share on other sites More sharing options...
jreich888 Posted May 5, 2021 Author Share Posted May 5, 2021 Looks like it's just a bad camera. Once I pulled the backup camera and plugged it directly into the monitor (special Sony 6-pin connector) there is sound but no video. I was thrown off by the fact that I could not get the triptek to work reliably, as it needs a good video signal input to add it's overlay. I assumed it could produce a video in any case, but that guess sent me off in multiple dead ends. So it looks like a drop-in replacement color camera with the same connector (6pin mini-din) from rvcams.com costs $325, seems pretty crazy. Anyone found other options? Link to comment Share on other sites More sharing options...
