Chuck B 2004 Windsor Posted June 14, 2021 Share Posted June 14, 2021 You might want to check your universal joints. When is the last time you greased them before this time? They should be greased every 3 or 4 thousand miles. Make sure they are in Phase with the correct drop angle at ride height. If the U joint that is closest to the front of the coach fails and drops down, you will do a lot of damage to the rear end, transmission, and the engine. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
