ken.knutson100 Posted July 31, 2021 Share Posted July 31, 2021 The front heated floor control has no power. Doesn’t even show off on the lcd screen. The rear heated floor shows on. It’s worked before but it’s been awhile since I’ve used it. Am I missing something? Link to comment Share on other sites More sharing options...
John Haggard Posted July 31, 2021 Share Posted July 31, 2021 Did you check ✔ your AC breaker box They are marked Link to comment Share on other sites More sharing options...
jcavataio5255 Posted August 1, 2021 Share Posted August 1, 2021 Hi Ken , Can you hear any relays randomly clicking? from your Automatic Energy select switches? (P/N 00-00714-00) not sure where they are in your coach maybe in the rear closet assuming you have one? Or possibly under the floor in the back somewhere? If you do, it could be a bad Automatic energy switch! I just had the same problem. John C 2009 Navagator Link to comment Share on other sites More sharing options...
ken.knutson100 Posted August 1, 2021 Author Share Posted August 1, 2021 (edited) 1 hour ago, John Haggard said: Did you check ✔ your AC breaker box They are marked I did but didn’t see any breakers tripped? They should both show up on the LCD display even if off correct? And not you have to have the AC off or rear one on (which neither made a difference)? 7 minutes ago, jcavataio5255 said: Hi Ken , Can you hear any relays randomly clicking? from your Automatic Energy select switches? (P/N 00-00714-00) not sure where they are in your coach maybe in the rear closet assuming you have one? Or possibly under the floor in the back somewhere? If you do, it could be a bad Automatic energy switch! I just had the same problem. John C 2009 Navagator Umm..yes!!! I do!! I was wondering what that was! Exactly what is going on! Where do you get one of those? We are selling the coach and will need to get it fixed before selling. And I’m guessing it isn’t cheap?! 😬 edited: I just looked on eBay and they are under $100 so that’s not bad at all considering I paid $2700 to get the cruise fixed on it because this coach has the Kong chassis control box and not the VIP one that is readily available! 😡 Edited August 1, 2021 by ken.knutson100 Add text Link to comment Share on other sites More sharing options...
jcavataio5255 Posted August 1, 2021 Share Posted August 1, 2021 Ken, I bought mine off Amazon Link to comment Share on other sites More sharing options...
ken.knutson100 Posted August 1, 2021 Author Share Posted August 1, 2021 9 minutes ago, jcavataio5255 said: Ken, I bought mine off Amazon Thank you! That’s exactly what it did now! Thank for the help too!! I would never have figured this out on my own! And that clicking would have just kept going on! It affects the battery charging too I think because the charger voltage kept going down every time the clicking would happen. And of course the lights would dim Now if I can just get the low coolant sensor tho v figured out 🤷🏻♂️ Link to comment Share on other sites More sharing options...
