MagnumR01 Posted April 12, 2023 Share Posted April 12, 2023 (edited) 2001 Renegade Sedona. MAGNUM R series chassis. Wish I had a wire diagram but found issue anyways. Had a no start no air heat light when turning key. Turned out to be no ecm power going to the fuse relay panel behind battery bank. The white ignition wire labeled ignition on wire was broken upstream. The break was behind right side dauls about frame height. Spliced it heat shrunk connection and walla. She is alive! Edited April 12, 2023 by MagnumR01 Link to comment Share on other sites More sharing options...
