WBDave54 Posted July 22, 2020 Share Posted July 22, 2020 2004 Monaco Windsor. After a drive turned parking lights off but they continue to stay lit. Have replaced headlight switch with new Delco, also disconnected switch completely with same result. Have a Smart wheel. Thanks Link to comment Share on other sites More sharing options...
merkur89xr4tiride Posted July 22, 2020 Share Posted July 22, 2020 I’d look for a relay, that gets power from the headlight switch to activate, that is hanging up. Tap on relays in the side compartment under the drivers window Link to comment Share on other sites More sharing options...
WBDave54 Posted July 22, 2020 Author Share Posted July 22, 2020 Thanks for response. After doing the usual what did I do to screw it up I looked around back since I had backed out of a tight spot and thought I heard a scrap. Sure as poop connector to toad was mangled and hot wire was feeding back into parking light system. Am I the only one that does self inflected wounds to there old girl. Link to comment Share on other sites More sharing options...
