Bobkat11208 Posted May 18 Share Posted May 18 On the driver side, there is what I assume is a map light under the overhead cabinet . There is a similar one on the DW side. While changing out all fluorescent tubes today to LED, I went ahead and changed both lamps installing LEDs. On her side is a clearly marked switch which illuminates hers (both the old bulb and the new LED light up). It does not and has not lit mine. For the life of me, I do not see a similar switch on the driver side (again hers does not and never has illuminated mine). Thoughts? edit: this is NOT the fixture under the TV cabinet nor a gooseneck lamp; it is more a puck light similar to those under the cabinets above the couch and love seat (maybe 3” diameter with a screw off bezel). TIA. Link to comment Share on other sites More sharing options...
Elizlampe Posted May 18 Share Posted May 18 Drivers side is the headlight switch turned all the way to left or right. Don't remember but that is the "switch" for the map light. At least on my 2000 diplomat Link to comment Share on other sites More sharing options...
Bobkat11208 Posted May 18 Author Share Posted May 18 Yep. That works. Thanks. Link to comment Share on other sites More sharing options...
