Preston W Posted June 3, 2024 Posted June 3, 2024 Hi all, We lost this piece in an accident near Bakersfield, in fact, the whole section was knocked olf and is somewhere along CA 99. southbound. Everything was too chaotic to try and look for it. Our Body shop in Phoenix is looking for a replacement and wants to make sure they get the right piece. I'd appreciate any measurement of this. Its inset into the frame with four screws and should be about5 43 inches wide and 26 inches high. I have taken it off a number of times to re rivot the various fins. The vent on the other side is smaller. Thanks for any info. pics attached where it use to go.
Craggar Posted June 3, 2024 Posted June 3, 2024 Will a 98 Monaco be the same? If so I can measure up in the morning for you.
Preston W Posted June 3, 2024 Author Posted June 3, 2024 Hi Exactly. Ours was a 1998 aMonaco Dynasty. we had a 8.3 Cummins engine.I think. I don't know if that makes a difference in the radiator size.And our coache was a duke layout forty foot long. I do appreciate it. The body shop just gave me the repair estimate... over forty thousand dollars. Ouch
Craggar Posted June 3, 2024 Posted June 3, 2024 (edited) Ok it’s raining today but I will go out in the morning and measure it up for you. Mine is the 8.3 with side rad as well. Edited June 3, 2024 by Craggar
Tony G. Posted June 4, 2024 Posted June 4, 2024 (edited) My dynasty is a 1998 40 foot with the drivers side slide. The dimensions of the side fins for the radiators are just under 50 inches wide by 23 inches high Edited June 4, 2024 by Tony G. 1
Preston W Posted June 4, 2024 Author Posted June 4, 2024 Thanks very much for your trouble. Ihave no slides but bet its the same size.
Craggar Posted June 4, 2024 Posted June 4, 2024 15 hours ago, Preston W said: Thanks very much for your trouble. Ihave no slides but bet its the same size. I'm guessing you don't need me to measure mine anymore?
Preston W Posted June 4, 2024 Author Posted June 4, 2024 No, we are ok. Unless you don't have a slide, perhaps the size might be slightly different.We have no slides.
Craggar Posted June 4, 2024 Posted June 4, 2024 Mine is a Windsor and has the slide as well but the measurements are the same as posted above.
Preston W Posted June 4, 2024 Author Posted June 4, 2024 Thank you very kindly for your efforts and enjoy your day. 1
