KenGor Posted June 18, 2024 Posted June 18, 2024 My brake lights do not work when activated by the brake pedal. Additionally, they will not cancel the cruise control. They do work when the PAC brake is activated and decelerating. I have checked all the fuses and switched relays in the Monaco 2 box. I am assuming the problem is at the brake light switch. I have scoured the internet looking for the location of the switch(s) with no luck. I cannot find the two switches commonly referred to in the posts. Below is a picture of the only thing on the firewall I think could be a brake light switch. It appears to have an air connector and two electric conductors. The second pic shows part of the brake pedal system under the dash. Note: My coach has the RR8R suspension that may be unusual for a 2005 model. ANY SUGGESTIONS ON MY DIAGNOSIS AND THE LOCATION OF THE SWITCH(S) IF I AM CORRECT?
