Skip Smith Posted September 28, 2020 Share Posted September 28, 2020 I have an electric winegard tv antenna, model # MA1055W. Unit will not drop down or turn, from the inside display panel. Raised up good, and turned, but would not retract the next day. Years ago, I replaced the bat wing, with a Jack antenna. Drove home, 200+ miles, with the antenna up, didn't hit anything. Got up on the roof, moved antenna to home position, and pushed down. Will not raise. When pushing the raise/stow button, the motion light, lights up, does not move, and then all 3 lights flash and go out. Winegard says the antenna is discontinued, and no parts available. Does anybody have a wiring diagram, and most likely a motor for this unit. Any help would be greatly appreciated. Thanks. Link to comment Share on other sites More sharing options...
