Mike Wahl Posted November 14, 2020 Share Posted November 14, 2020 We have recently purchased a 2001 Monaco Signature. It has a Norcold 1200 fridge with the recalls done. I'm working on putting it away for the winter, however I can not get the fridge to shut off. I push and hold the off button for 3 seconds as stated in the manual but it will not turn off and the on display light in the corner of the dispaly screen stays on. There are no fault codes and I can switch between modes of operation. Has anyone else had this issue? I thinking it might be a bad optical control assembly. Mike Link to comment Share on other sites More sharing options...
Bobsteid Posted November 14, 2020 Share Posted November 14, 2020 We have an 02 signature Turns off ok Try to power of all of the rv (battery disconnect) It should turn off and stay off till you turn it back on Link to comment Share on other sites More sharing options...
Keith Moffett Posted November 14, 2020 Share Posted November 14, 2020 Not a fan of any gas absorption fridge. When they get older they become more hazardous. New residential fridges use way less power than just a few years ago. We just run our generator twice daily while dry camping. Link to comment Share on other sites More sharing options...
Mike Wahl Posted November 14, 2020 Author Share Posted November 14, 2020 (edited) 4 hours ago, Keith Moffett said: Not a fan of any gas absorption fridge. When they get older they become more hazardous. New residential fridges use way less power than just a few years ago. We just run our generator twice daily while dry camping. Keith, What kind of residential fridge do you have? We will be doing a lot of boondocking, and are concerned about that. Where we stay normally we cant run the generator overnight. Do you have solar? Edited November 14, 2020 by Mike Wahl Link to comment Share on other sites More sharing options...
Mike Wahl Posted November 14, 2020 Author Share Posted November 14, 2020 8 hours ago, Bobsteid said: Try to power of all of the rv (battery disconnect) It should turn off and stay off till you turn it back on I used the battery disconnect and shut down the power. On startup the fridge turns right back on. Link to comment Share on other sites More sharing options...
Bobsteid Posted November 15, 2020 Share Posted November 15, 2020 Wow I think from the outside panel there is a fuse and a plug Ours is put away for winter 1 Link to comment Share on other sites More sharing options...
Keith Moffett Posted November 15, 2020 Share Posted November 15, 2020 2 hours ago, Mike Wahl said: I used the battery disconnect and shut down the power. On startup the fridge turns right back on. Mike, we had a 1200 LRM Norcold and every time they did a recall things just got worse. These fridges are supposed to last about 10 years and if they go longer its icing on the cake. After seeing all the fires caused by RV fridges, especially Norcold its too much risk! We have an 07 Beaver with a Jenn Air residential fridge. It draws 13 amps. New fridges draw way less. Costco offers a Whirlpool and a Samsung that appear about comparable in size to the 1200LE but about half the price. Yes we have solar but not much. We do have a couple extra house batteries. 1 Link to comment Share on other sites More sharing options...
