trailmug Posted April 23, 2021 Share Posted April 23, 2021 Our coach has rubber seals/gutters installed roughly between the Girard awnings and the roof, which appears to be intended to direct water to run off at given points (I think to avoid pooling near the awning perforations). I need to reconfigure one of these because it's channeling water over an aftermarket wheelchair door and exceeding that door's ability to seal. Any idea where I can find some of this stuff? It appears to be neoprene. I tried Pelland and a few other Google searches, but I'm not sure exactly what it's called. Thanks for any input, Rob Link to comment Share on other sites More sharing options...
Jim McFarland Posted April 23, 2021 Share Posted April 23, 2021 I think I have purchased RV gutter at Camping World. It is usually available in only black or white. Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted April 23, 2021 Share Posted April 23, 2021 That looks a lot like the garage door seal sold at big box & hardware stores. Some slide seals may be like that as well. Link to comment Share on other sites More sharing options...
Paul J A Posted April 23, 2021 Share Posted April 23, 2021 5 hours ago, trailmug said: Our coach has rubber seals/gutters installed roughly between the Girard awnings and the roof, which appears to be intended to direct water to run off at given points (I think to avoid pooling near the awning perforations). I need to reconfigure one of these because it's channeling water over an aftermarket wheelchair door and exceeding that door's ability to seal. Any idea where I can find some of this stuff? It appears to be neoprene. I tried Pelland and a few other Google searches, but I'm not sure exactly what it's called. Thanks for any input, Rob Try ; steelerubber.com Their phone customer service is excellent and they will send samples for you to try. 1 Link to comment Share on other sites More sharing options...
trailmug Posted April 23, 2021 Author Share Posted April 23, 2021 Thanks, it looks exactly like https://www.steelerubber.com/flexible-edge-trim-70-4104-244 Link to comment Share on other sites More sharing options...
