Posted
Does anyone know how to reattach the lower shower door brackets? mine have slowly come off and now none of them are attached as you can see in the pictures.
Posted
Maybe unhook top, slip in bottom and pull up to set top rollers in. Just guessing!!!
  • 1 month later...
Posted
Thanks, you where close, I loosened the bolts on top of the rollers which lowered the doors about 1/4" so the hooks would easily fit in bottom track, but only the first one would stay in the track when I tightened up the bolts. I then noticed that the first roller "axle" was lower than the other three rollers Appears the axles are not centered and if it's lower the door is held up higher. So I took the other rollers off, turned them over and tightened them up while I held the bottom hooks in with my foot. Worked great, no more floppy door.
