IEMan 1 Posted May 14, 2022 Share Posted May 14, 2022 Hello, I've got a 2006 Dynasty. Just noticed that the brake lights are not working at all. The running lights, turn signals & 4-ways work good. Checked the in the upfront bay, fuse and relay in engine comartment both good. There is power at the air pressure switch when brake pedal is pressed up front also. Anyone know what I am missing? Link to comment Share on other sites More sharing options...
bradc344 Posted May 14, 2022 Share Posted May 14, 2022 Hi I hade the same trouble on my Holiday Rambler diesel and we checked everything and finally took it to shop and it turned out to be corroded wires at the trailer plug cleaned it up and all is good ,good luck Link to comment Share on other sites More sharing options...
Ivylog Posted May 14, 2022 Share Posted May 14, 2022 Power at the brake switch means the switch is bad… switch supplies the ground for the brake lights. Link to comment Share on other sites More sharing options...
