Woody O Posted June 22, 2022 Share Posted June 22, 2022 While coming home from my last trip, my rear view camera and radio started going blank for about 30 seconds and then come back on and continued to do this, not on a schedule, for the remainder of the trip, which was about four hours. I’m thinking it is a grounding issue. What do you guys think? On a 2006 Dynasty, where do I need to search under the dash to find the ground bus bar? Woody O 2006 Dynasty Link to comment Share on other sites More sharing options...
redeye0315 Posted June 22, 2022 Share Posted June 22, 2022 I would first suspect a loose feed cable into the back of the monitor or the back of the camera. That traveling earthquake tends to loosen them up over time. Your ground bar though will be located in the front, behind the generator slide on the firewall. Link to comment Share on other sites More sharing options...
Woody O Posted June 22, 2022 Author Share Posted June 22, 2022 Thanks Redeye, I will check there first Link to comment Share on other sites More sharing options...
