63Hotrod Posted July 4, 2022 Posted July 4, 2022 Our small bedroom slide is a cable slide. When I put the small bedroom slide out just now I noticed the top forward and back bottom cables were not visible. No sign of broken cables at the bracket they were just not visible. Motor runs fine and slide still comes in and out with just two cables, But I would not trust it to not jam up I took apart the inside top facia to gain access to the motor etc. What I see is a good loop of slack for the bottom cable on the right and a loop of slack on the left for the top cable. Can't pull them out past whatever other pulley there is I can figure out where the cables route once they leave the top compartment. How do you get access to the rest of the cable routing?
