Bob Jones Posted July 7, 2022 Share Posted July 7, 2022 Hi folks! I'm working on my parents new motorhome and fixing the factory screw-ups. On the furnace they knocked out the wrong plug and ideally the hose should be routed to a different hole. The question is, how do you block off the old hole when they knocked the plug out of it? Link to comment Share on other sites More sharing options...
Tony G. Posted July 7, 2022 Share Posted July 7, 2022 The simplest way is to find something that is light gage aluminum or light gage steel. Something you can cut into a square that will cover the old hole. Should be able to find something at Home depot or Lowes. While you are at the store get some aluminum tape. Cut the metal to cover the hole and tape it with the aluminum tape. That will seal it up just fine. If you want you can add some butyl gasket around the hole before you put the metal on. 1 Link to comment Share on other sites More sharing options...
Reka52 Posted July 7, 2022 Share Posted July 7, 2022 Electrical cover plate ? Might have to design a screw lock with a sheet strip and self tapping screw 1 Link to comment Share on other sites More sharing options...
Bob Jones Posted July 7, 2022 Author Share Posted July 7, 2022 Thanks guys, I'll do exactly that. Link to comment Share on other sites More sharing options...
Rocketman3 Posted July 7, 2022 Share Posted July 7, 2022 Search Amazon Suburban 050733 Duct Cover Plug if you want the part premade. 1 Link to comment Share on other sites More sharing options...
Bob Jones Posted July 13, 2022 Author Share Posted July 13, 2022 On 7/6/2022 at 9:37 PM, Rocketman3 said: Search Amazon Suburban 050733 Duct Cover Plug if you want the part premade. Thank you, I went that route because I could get it quickly and cheaply locally. It worked like a top! So clearly suburban and Dometic use the same size holes ! (4 ") Link to comment Share on other sites More sharing options...
