Gary M Posted July 30, 2022 Share Posted July 30, 2022 What is used on plumbing connections to black and gray tanks? Mine is cracking on black vent pipe allowing a not so good odor for my nose. Is it maybe a tread sealant? I need to add more to reseal vent pipe. TIA Gary M Link to comment Share on other sites More sharing options...
SteveC Posted July 31, 2022 Share Posted July 31, 2022 Gary, RV black and grey water tanks are made from ABS plastic. Epoxy and sealers do a poor job of sticking to ABS. Repairs to ABS use ABS plastic sheeting or shavings and either melt the materials together using heat or chemicals. I suggest you remove all the white sealer around the joint and determine if it is cracked and broken. I had a fifth wheel black tank that had a crack on the drain neck. The previous owner had filled the crack with epoxy and sealer but it still leaked. I used Plasti-mend with ABS mesh. Search for ABS repair kits and Plasti-mend kits. Good luck. 1 Link to comment Share on other sites More sharing options...
Gary M Posted July 31, 2022 Author Share Posted July 31, 2022 (edited) 2 hours ago, SteveC said: Gary, RV black and grey water tanks are made from ABS plastic. Epoxy and sealers do a poor job of sticking to ABS. Repairs to ABS use ABS plastic sheeting or shavings and either melt the materials together using heat or chemicals. I suggest you remove all the white sealer around the joint and determine if it is cracked and broken. I had a fifth wheel black tank that had a crack on the drain neck. The previous owner had filled the crack with epoxy and sealer but it still leaked. I used Plasti-mend with ABS mesh. Search for ABS repair kits and Plasti-mend kits. Good luck. Thankyou. I just remembered when I lived on a sailboat, I made a drip pan out of ABS. I cut some ABS on my tablesaw and took the shavings, mixed I think with acetone and made a ABS glue and to put it together with. So yes I will remove to see what’s cook’n. Edited July 31, 2022 by Gary M 1 Link to comment Share on other sites More sharing options...
