JJMonaco Posted August 2, 2022 Posted August 2, 2022 (edited) Today when I tried to open a basement door on my 2002 Signature, the pot metal handle broke away from the rod that it is supposed to turn to actuates the lock mechanism. Does anyone know the correct name for this part and where to find a replacement? John J Edited August 2, 2022 by jjroxus
Ranger Rick Posted August 2, 2022 Posted August 2, 2022 Could that be fixed with JB Weld? It’ll do until you can find a replacement.
JJMonaco Posted August 3, 2022 Author Posted August 3, 2022 I don’t think it would work if you could get it JB welded. The piece that broke off is only about 3/8 of an inch long. It’s made of what I know as pot metal aluminum casting. That handle piece has a flat spot that mates with a flat area on the rod. When the door handle is lifted that small area that broke off the handle takes all the torque to turn the rod that releases the locking mechanism. It’s a faulty design in my opinion to have such a small area take that much pressure at only one end of the handle. The good news is that I located the replacement. It took a-lot of internet searching over a couple of days, but luckily I came across s photo of of a similar looking item and the manufacturer was listed as Trimark Industries. I looked up the Trimark’s website and found s lot of info. I called them and found it is still available. They have an amazing customer service person that helped me identify the part number. They make a lot of versions of the model 030-0850. For my 2002 Monaco Signature the Model is 030-0850 with a part # 131110146T They do same day shipping and FEDEx would have it to me in three to four days for a total cost of about $135. I will report back if when it arrives and I get installed.
JJMonaco Posted August 6, 2022 Author Posted August 6, 2022 I received the replacement basement door handle / lock for my 2002 Monaco Signature 40. It was an easy install and it seems to be the exact replacement. Here is a drawing of the part from the Trimark website. 18481-xx.pdf John J
