Gonzalo Posted October 11, 2022 Share Posted October 11, 2022 I have a 2005 Monaco Windsor Entry Door awning Marquee broke one end tip that slide inside the track I can find parts and the whole awning is 1500 Link to comment Share on other sites More sharing options...
Ron Shantos Posted October 12, 2022 Share Posted October 12, 2022 A machine shop can weld and shape that piece. Link to comment Share on other sites More sharing options...
Gonzalo Posted October 12, 2022 Author Share Posted October 12, 2022 On 10/5/2022 at 9:17 PM, David White said: Gonzalo, I have the same MH and as pointed out, the little magnetic switch is under the step. There is a wired half and another half that matches up when the step is closed. Put the step out to see if part has come off, but be careful because it can close and cause injury. When closed, the parts should be close together so the magnetic activates the switch and turn off the light. If the parts are in near contact and the light still stays on, it might be a faulty switch. Mine still gives be a light intermittently! Link to comment Share on other sites More sharing options...
