tjones8 Posted April 18, 2023 Share Posted April 18, 2023 On my 2093 Diplomat, when head lights are on, the right turn signal will not work. Any thoughts on where to begin? Link to comment Share on other sites More sharing options...
Ivylog Posted April 18, 2023 Share Posted April 18, 2023 So, the R blinker works until you turn on the headlights? You have a bad ground as It’s getting a ground through the headlight until you turn it on is my educated guess. 1 1 Link to comment Share on other sites More sharing options...
Bootlegger Posted April 18, 2023 Share Posted April 18, 2023 Sounds like a ground wire issue. I recently had the same issue and I found a loose wire on 1 of my pigtail connectors which was not all the way connected. I started by checking my wiring harnesses and following them to the left light. When I started moving the wiring harnesses I noticed the blinker started working. It can take some time time tracing out a ground issue. 1 1 Link to comment Share on other sites More sharing options...
SteveC Posted April 18, 2023 Share Posted April 18, 2023 43 minutes ago, Ivylog said: So, the R blinker works until you turn on the headlights? You have a bad ground as It’s getting a ground through the headlight until you turn it on is my educated guess. I was going to suggest the same issue. I agree with Bootlegger that it sounds like a ground issue. 1 Link to comment Share on other sites More sharing options...
tjones8 Posted April 19, 2023 Author Share Posted April 19, 2023 Thank you all Link to comment Share on other sites More sharing options...
