Chargerman Posted May 15, 2023 Share Posted May 15, 2023 I need to replace a solenoid for one of my slides. The solenoids are mounted at the pump. What trick have you guys used to remove them? I know they just unscrew but the issue is that between the hydraulic lines and the closeness of the adjacent solenoid I haven’t thought of a way to remove one. What trick did you use? Link to comment Share on other sites More sharing options...
Todd P Posted May 16, 2023 Share Posted May 16, 2023 When I had to replace a middle one I ended up taking out the one next to it first so I could get channel locks on it. Just make sure to relieve the pressure first. Link to comment Share on other sites More sharing options...
Tony G. Posted May 16, 2023 Share Posted May 16, 2023 I used my vise grip oil canister pliers to remove mine Link to comment Share on other sites More sharing options...
