1nolaguy Posted November 13 Share Posted November 13 When I took out the Norcold 1200 to install a 120v residential refrigerator there were two pairs of 12v DC wires (2- red and 2- white) that I disconnected and left in the rear of the cabinet. The wires must have shorted out as they show no voltage. I am guessing a fuse is blown. I also am guessing they are on a stand alone circuit as I can find no other 12v not working. I have looked in the House 12v panel and also in the chassis panel (bay below driver's seat in front road side but can not find a circuit labeled for this or a blown fuse. I have also checked all the 12v electric schematics I have down loaded and can not find a reference for the Fridge 12v. Any assistance would be appreciated as I want to use these lines if possible. Link to comment Share on other sites More sharing options...
johncvandoren@gmail.com Posted November 14 Share Posted November 14 (edited) Is your fridge in a slide-out? Mine was, and I found a loose molex connection where the fixed wiring goes to the flex wiring to the slideout. It was under the false bottom of the cabinets under the dinette table. Under the subwoofer, if I recall correctly. So not a fuse, but rather just a bad connection. Edited November 14 by johncvandoren@gmail.com Grammar Link to comment Share on other sites More sharing options...
1nolaguy Posted November 14 Author Share Posted November 14 John, The fridge is not on a slide. It is mounted above a furnace. As I recall the original Norcold had the 4 12v lines connected to the circuit board (CB). Two may have been incoming current and the other two (small gauge) might have been 12v current from the CB to another connection down stream. Link to comment Share on other sites More sharing options...
johncvandoren@gmail.com Posted November 14 Share Posted November 14 (edited) 5 hours ago, 1nolaguy said: John, The fridge is not on a slide. It is mounted above a furnace. As I recall the original Norcold had the 4 12v lines connected to the circuit board (CB). Two may have been incoming current and the other two (small gauge) might have been 12v current from the CB to another connection down stream. I found that Monaco “hid” three or more fuses in different places. One on the 12v panel below the main 120v CB panel in the rear bath, one in the front run bay beneath the driver’s seat, and one on the Norcold circuit board. There was also a 120V tube-type fuse on that board for the electric heater elements, in addition to one CB labeled “Refrigerator” on that main 120V CB panel. Good luck! Edited November 14 by johncvandoren@gmail.com Spelling Link to comment Share on other sites More sharing options...
1nolaguy Posted November 14 Author Share Posted November 14 Thanks John. Got love the engineers at Monaco. Always keeping things interesting. Link to comment Share on other sites More sharing options...
Trinidaddave Posted November 14 Share Posted November 14 Loel, did you check each wire to a known good ground with your meter? Also did you check each wire with ohm meter to ground? There is a possibility your ground is missing and 12 volts is available searching for the ground. Link to comment Share on other sites More sharing options...
1nolaguy Posted November 15 Author Share Posted November 15 David, good suggestion. I tested the wires grounding to the furnace body (metal housing) as I assumed it was grounded. I will run a ground wire direct from the chassis and test out each wire that way to see if any has 12v. Link to comment Share on other sites More sharing options...
