Xclusive Posted December 26, 2023 Share Posted December 26, 2023 Good afternoon, I have a 1999 Monaco Signature Series and I'm having a hard time figuring out why I have no ignition power to the rear starter solenoid. When I turn on the key the only thing hot to the rear of the coach is the neutral safety relay and one hot wire on the left side of the starter solenoid. When you turn the key over there is a switch that clicks out just behind the TV in bedroom. It is inside a small gray electrical box and I'm not sure exactly what that does. I have checked all fuses, changed out relays, changed out starter solenoid with no luck. I'm thinking there is a starter interrupter somewhere in the system cutting power but I cant locate it. I found a Trekmate security system booklet in the files that came with the rv. It shows there to be a momentary switch to override this system but I've had no luck locating. I can make the RV start by sticking a 12v hot wire directly to the ignition relay and using a starter button on the starter. Any advice would be appreciated. Link to comment Share on other sites More sharing options...
Solution windsorbill06 Posted December 26, 2023 Solution Share Posted December 26, 2023 Any chance you bumped the rear engine compartment remote start button? Link to comment Share on other sites More sharing options...
Oldgoat Posted December 27, 2023 Share Posted December 27, 2023 If you can't start it from the rear or front starter switch it could be a starter solenoid if your fuses are good. Link to comment Share on other sites More sharing options...
Xclusive Posted December 28, 2023 Author Share Posted December 28, 2023 Thanks guys it was the switch for the rear start. It was in the middle position and I had no idea there was a middle position on that switch. Link to comment Share on other sites More sharing options...
