Michel Posted January 17 Share Posted January 17 Hi, Monaco Caymen 2003 with a Level Best system and the control board routinely does not work. I disconnect everything to reset it and sometimes it work, sometimes it don't. Is there someone with a solution? I called Lippert and all they have is a Winnebago touch pad. They also have somethings like a universal pad that is supposed to work with all system but the wires are not the same, mine has two set of wires, two plug, the touch pad proposed by E trailer has only one plug. Is there a wire bundle to connent from my old wires to the new board? Or any other way I can have this old one modified or install direct switch? Part number for the control board / touch pad is 906900406 Link to comment Share on other sites More sharing options...
