Kenster Posted February 4 Share Posted February 4 (edited) My front passenger side main awning extended approximately 2 ft and stopped. Will not extend nor retract. Fuse in front driver side compartment is good. Master awning switch is on an illuminated. I will check extend/retract switch, but I highly doubt that's the problem. Does anybody know where the awning relay is located on this coach? I do have all the wiring diagrams for the coach if necessary. Edited February 4 by Kenster Trying to delete. I double posted. Link to comment Share on other sites More sharing options...
Solution Kenster Posted February 4 Author Solution Share Posted February 4 I found a small relay behind the switch. I checked connections and the awning is now working. 1 Link to comment Share on other sites More sharing options...
