Bobkat11208 Posted May 18 Share Posted May 18 On the driver side, there is what I assume is a map light under the overhead cabinet . There is a similar one on the DW side. While changing out all fluorescent tubes today to LED, I went ahead and changed both lamps installing LEDs. On her side is a clearly marked switch which illuminates hers (both the old bulb and the new LED light up). It does not and has not lit mine. For the life of me, I do not see a similar switch on the driver side (again hers does not and never has illuminated mine). Thoughts? Link to comment Share on other sites More sharing options...
bklaes Posted May 18 Share Posted May 18 On my 05 Diplomat, rotating the headlight switch to the left… Link to comment Share on other sites More sharing options...
Bobkat11208 Posted May 18 Author Share Posted May 18 Ta da 😂 Success! Appreciate the quick response Bill. And bonus, it turns on the 2 lights directly under the TV cabinet. Thanks. Link to comment Share on other sites More sharing options...
3pedal Posted May 22 Share Posted May 22 I had the same question. Turning the headlight switch doesn't work for me. It does turn on the ones under the TV cabinet. Now I think I will look at the bulb to see if it is burned out. 1 Link to comment Share on other sites More sharing options...
